Old 03-01-2015, 01:37 PM   #1
Weight Distribution Sabre Silhouette 298RLTS
Tow vehicle: 2010 F350 6.4L Diesel, Crew Cab, Full Bed, Air Shocks on rear, single tire drive axle.
Trailer: 2014 Sabre Silhouette 298RLTS 5th wheel
Tire Pressures: steering axle 65 pounds
drive axle 80 pounds
trailer tires: 65 pounds
CAT Scale Results:
steering axle: 5420 pounds
drive axle: 5480 pounds
Trailer axle: 8380 pounds
Question: Do I have a problem pulling this load? I really do not understand this
load factor, especially calculating tongue weight (king pin on receiver).
Not real import question, however do the letters on my model mean anything
dlmurray51 is offline   Reply With Quote
Old 03-01-2015, 01:54 PM   #2
Platokidd's Avatar
this may help
Fifth Wheel Weight Calculator
This is a good to from our library here on the forum:
http://www.forestriverforums.com/for...do=file&id=129
Just a guess here, Rear Living Room Table Slide??
Mine stands for , Rear Seating Theater -Touring Edition - Champaine.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
R.I.P. Luke the campin dog
Platokidd is online now   Reply With Quote
Old 03-01-2015, 02:08 PM   #3
heavynlori's Avatar
Rear living triple slide??
heavynlori is online now   Reply With Quote
Old 03-01-2015, 02:22 PM   #4
Platokidd's Avatar
Thinking you may be right
Seasonal
Old 03-01-2015, 02:23 PM   #5
asquared's Avatar
Did you do a weight without the trailer by chance? A weight without the trailer will help you calculate exact trailer weight and pin weight as well as your available payload and adjusted towing capacity. Knee-jerk reaction without knowing more info is you are probably ok.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 03-01-2015, 02:26 PM   #6
Platokidd's Avatar
X2
Seasonal
Old 03-01-2015, 02:40 PM   #7
fonzie's Avatar
You can figure it out by looking at the 2010 Ford Towing guide......
Towing Guides | fleet.ford.com
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 03-02-2015, 10:39 AM   #8
Wink Fifth Wheel Weight Calculator
I want to thank everyone for your input. The next thing I will do is weight the tow vehicle loaded, minus the trailer. Thank you for directing me to the Fifth Wheel Weight Calculator. Will post results when done.
Old 03-02-2015, 11:23 AM   #9
Fulltime family RVer
When you weigh, try to get both weights at once (with the camper attached and truck alone):
Learn To RV: How to Weigh a Fifth Wheel Camper (at CAT Scales)
Then, you can plug them into my calculator here:
Actual Weights - Fifth Wheel Weights from CAT Scales - Towing Planner
Old 03-17-2015, 05:29 PM   #10
Just finished weighing tow vehicle only 2010 F350 SRW, long bed
Steer Axle: 5220
Drive Axle: 3440
GVW: 8660
Thanks to ependydog Actual Weights-Fifth Wheel Weights, results are as follows:
Truck and Camper Hook Up
Steer Axle: 5420
Drive Axle: 5480
Trailer Axle: 8380
Truck Only
Steer Axle: 5220
Drive Axle: 3440
Results:
Gross Combined Weight: 19280
Truck Weight (Hitched): 10900
Truck Weight(truck only) 8660
Camper Weight: 10620
Pin Weight: 2240
Pin Weight Percentage: 21.1%
Tire and Axle Loads
Number of Axles: 2
Individual Axle Weights; 4190
Individual Tire Weights; 2095
sabre, weight
