Old 06-09-2019, 07:52 PM   #1
What am I Looking at in the Circuit Box?
This is the inverter / circuit breaker / fuse box on my new 2019 31BHSC. I want to buy replacement fuses to have on hand just in case, but I'm not sure what I'm looking at here.
In this first image, I see the 15 amp fuses well enough and I guess that's a 1 amp fuse. What is the large 12v30amp thing in the middle? What are the two things that look like fuses in the upper right hand corner labeled 5E?
I'm also wondering what the green light is telling me in the second image.
ScenicView is offline   Reply With Quote
Old 06-09-2019, 07:59 PM   #2
Coach
Attachment 206855
Attachment 206856
I think if you turn your SE fuses upside down, you'll find they say 35.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 06-09-2019, 08:13 PM   #3
Ha! Part of the mystery solved! Thanks. Any idea what the 12v 30 amp is?
Old 06-09-2019, 08:21 PM   #4
bikendan's Avatar
You mean CONverter, not INverter.
Equalizer WDH
Old 06-09-2019, 08:27 PM   #5
Good point. Iíll get the hang of this sooner or later. Iíll do some basic wiring at home, but I donít understand this TT electrical system well enough to do anything more than kill the power and change a fuse.
Old 06-09-2019, 08:43 PM   #6
Just as confused as you
Scrapper's Avatar
Attachment 206855
Attachment 206856
The 12v30amp is a auto-reset breaker
The 2 5E or 35 amp fuses are the reverse polarity fuses. If you connect the battery backwards those will blow to protect your converters charger section.
I don't have an idea about the green light.
Richard & Jill
Camping since 1989, seasonal since 2000
Old 06-10-2019, 04:27 AM   #7
Is the 12v30amp for the slide outs? Do you know if it's replaceable like the other fuses?
Old 06-10-2019, 02:50 PM   #8
Scrapper's Avatar
I don't know if it's for the slideouts. Slides are usually wired directly to the 12vdc system because of the amount of amps needed and fused separately with an inline fuse. They are not connected to the fuse panel. Most manuals say to have your TT plugged into shore power when operating the slides. That auto-reset breaker should be removable as it just plugs into a fuse slot. You could remove it then try everything until you find what doesn't work. Is there anything written on the label of the door to the panel.
Richard & Jill
Old 06-10-2019, 03:20 PM   #9
bikendan's Avatar
The slideout on our Rockwood Roo trailer had its own 30amp fuse along the frame, next to the bottom of the slideout.
Equalizer WDH
Old 06-11-2019, 09:56 AM   #10
Head Rambler
What brand and model power center is that?
It's interesting to say the least.
Gotta go campin!
