Old 04-11-2014, 09:38 AM   #1
What light bulbs in the 34TBOK? Looking to replace with LED's
Can anyone tell me which bulbs are in the lights in Sabre units. I am looking at possibly getting some LED Replacements.
2013 Ram 2500 SLT 4 x 4 c/w 5.7L & 4.10 - 6spd Auto
2013 Palomino Sabre 34TBOK-6
2014 GMC Sierra SLE 4 x 4 c/w 5.3L - 6 spd Auto
2011 Crestliner Superhawk c/w 115HP Mercury
2012 Honda CBR250
iceman31 is offline   Reply With Quote
Old 04-11-2014, 10:21 AM   #2
TURBS's Avatar
Are they push in bulbs?
If so 912's 921 bulbs also used just brighter I believe.
TURBS
Sabre owners united!
Old 04-11-2014, 10:22 AM   #3
TURBS's Avatar
This
TURBS
Old 04-11-2014, 10:45 AM   #4
Here is what I bought - hope they will do the trick - if not I am out $26
20X T10 W5W 194 921 24 SMD LED DAY White CAR RV Roat Marine Light Lamp Bulb NEW | eBay
2012 Honda CBR250
Old 04-11-2014, 10:52 PM   #5
There are also some G4 Bulbs in the recessed lights in the main living area - got out to my unit and opened it up to look at what type of bulbs there are - Can someone verify that these are the G4 lights? Also what about the flood lights on the outside of the unit - what type of bulbs are in those 1156?
2012 Honda CBR250
Old 04-11-2014, 11:02 PM   #6
1156's
Mine are, got LED's to replace @ Amazon, E-Bay worries me as you don't know who you're buying from. I paid quite a bit less for the 921 replacements as I recall. Forest River reimbursed me any way as the trailer was supposed to have LED's.
leland1950 is offline   Reply With Quote
Old 04-14-2014, 06:52 PM   #7
BooBoo23's Avatar
You are going to have to take a look at each light fixture to determine what you will need and what will fit. LED replacements are a can of worms and will require a little home work. I am not familiar with your rig but I would guess that there are several styles of bulb base used. Could be a "wedge base" that simply pushes in, some have two straight wires that push in the socket, some have a bayonet base, push in and twist, with two opposing pins on the base, take note that some bayonet bases have the pins horizontally opposed and others are offset opposed depending on the contacts on the bottom. Some bayonet bases have a single contact on the bottom, others may have 2 contact surfaces on the bottom. There a couple other styles I haven't described. I replaced all the halogen bulbs in the last TT I owned and used 3 different style bases on the interior lights (wedge base and 2 different styles of bayonet base) and 2 styles on the exterior (marker lights and Stop/Turn/Run).
I bought all the lights on Ebay and patiently shopped for the right prices. Get at least 200 Lumens (more is better). Colors will vary also so google led colors to determine what suits you best. Naturally you don't want blue and possibly red for the Stop/Turn lights. "Cool white" seems to fairly popular but may have a slight blue tint. The brake/turn bulbs need to be at least 500 lumens.
My 2014 Palomino Puma 25RS has all LED interior lamps already installed and the one over the galley sink has a high/low brightness. I'll eventually get around to replacing the exterior bulbs a little later.
Good luck, when you get through you will be a lot smarter about LED's.
Marv
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
led, light
