Old 12-12-2015, 08:06 AM   #1
mach8274's Avatar
Wheel PSI rating...
I am planning on getting the Goodyear G614 tires early next year. Does anyone else have these wheels and are they rated for 110 PSI? I haven't had time to remove a wheel and look to see if it's stamped in the inside. This is the best pic I have that shows the wheels...
Dave & Amy
5 kids, 2 with 2 legs, 3 with 4 legs
2016 Columbus 385BH "No Worries II"
2016 F350 6.7L PSD CC Lariat DRW "Mistress II"
Ford factory puck system with 26.5k hitch
mach8274 is online now   Reply With Quote
Old 12-12-2015, 09:16 AM   #2
Kenny kustom's Avatar
I think I have those wheels on my sabre.
I have purchased Samson 110 psi tires for them. Will be installing in the spring.
I haven't looked for max psi on the wheels. Although, they came with 80 tires, so I have no concerns with them holding 110.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I am nice!
2017 Dynamax Isata 4
Old 12-24-2015, 01:04 PM   #3
I have the same tires on my 381FL and have the same concerns. I had the G614's on my previous coach and it had steel valves not rubber ones so that gives me thought about how much the wheels can handle. I know you can change out the valves to steel but I still have a question about the wheels. I would like to change out the wheels and tires but I don't know if the hubs will handle heavier wheels. I need to do some research!
Okie
Okie
Retired USMC&FAA
2015 Columbus 381FL
08 F450
USMC Okie is offline   Reply With Quote
Old 12-24-2015, 01:38 PM   #4
Are these the wheels in question?
16" 8 Lug Bearcat Black HD Aluminum Trailer Wheel
If so, it looks like they are fine for G rated tires. I'm with Kenny, nothing to worry about here. Just swap in some metal stems and good to go. By the way, a lot of places get $350 a tire for G614's. Amazon currently has them for $307 with free shipping.
http://www.amazon.com/Goodyear-Unist...&keywords=G614
Karl4Cat is offline   Reply With Quote
Old 12-24-2015, 01:48 PM   #5
I have an email from FR.
I just need to send them a pic of my wheels.
Rv is not here now, so can't as of yet.
2016 Sabre 36QBOK
I am nice!
Old 12-24-2015, 03:36 PM   #6
I did the same when I bought my GY's Kenny. XLR told me that they do G tires from the factory as an unadvertised option on the same rims that the E's go out on so no problem there. I'm betting it will be the same in this situation....
Old 12-24-2015, 04:21 PM   #7
Just take one off and look at the backside of the wheel. It should have the max tire pressure cast onto one of the spokes. I wouldn't take a chance unless you know for sure. Running too much pressure on a wheel not rated for it can split the rim.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 12-24-2015, 06:56 PM   #8
I would be a little cautious if it had come with c or d's.
But, it did come with 10 ply load e 80 psi, and metal valves.
I'll find out for sure, but am sure, they will be ok.
2016 Sabre 36QBOK
I am nice!
Old 12-25-2015, 09:21 PM   #9
mach8274's Avatar
Amazon.com: Goodyear Unisteel G614 RST Radial Tire - 235/85R16 126R: Automotive
Yes...those are the wheels. Thanks for the info. I actually found a local Goodyear retailer that will sell me the tires for $300 a piece. I already have my valve stems, ready to go in when I mount my tires. Thanks for all the input guys...I appreciate it.
Old 12-26-2015, 04:54 AM   #10
Excellent deal you found on the GY's! Enjoy the worry free towing experience...
wheel
