Old 04-30-2013, 05:17 AM   #1
Commercial Member
huntr70's Avatar
Wheel psi rating on Columbus?
Anyone have an idea if the oem wheels on a Columbus will take 100 psi?
Looking into Goodyear G614 tires, but I think they are rated for 100 psi instead of 80 that the China bombs take......
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 04-30-2013, 07:11 AM   #2
treaves's Avatar
If they are rated at 80, why would you risk tire failure by over-inflating them?
2012 Ram 2500 Laramie Limited CCLB CTD
2014 Columbus 320RS
treaves is offline   Reply With Quote
Old 04-30-2013, 07:11 AM   #3
Trailer Trash
Don't know wheel spec but do you think the 100psi tire would make for a harsher ride on bumps and bounce stuff around in RV more than it already does? Usually more PSI is needed to handle heavier weight. The RV did not get any heavier did it? Are you are planning on being over GVW?
joelek is offline   Reply With Quote
Old 04-30-2013, 07:14 AM   #4
Trailer Trash
China tires = 80psi. Goodyear tires = 100psi. Question is can the aluminum wheels handle the increased pressure.
I would think inside the wheel would be magic numbers showing psi rating and manufacturing info.
Old 04-30-2013, 08:03 AM   #5
SYE
SYE's Avatar
They should be stamped in the inside of the wheel.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 04-30-2013, 08:52 AM   #6
amxpress's Avatar
Yes, they can handle the pressure.
I recently looked at a Cedar Creek with the same rims. It had those GY LT tires from the factory and a GVWR of almost 16K.
As mentioned though, 100psi is a lot for your Columbus' weight.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 04-30-2013, 08:09 PM   #7
Commercial Member
huntr70's Avatar
Not really worried about running them on the Columbus, just way too many bad tires lately, and not risking tearing things up. On average, I see many more rv's on a daily basis than most of you. I did check the wheels, and they are stamped with manufacturer, weight rating, and style numbers, but no pressure rating.
Steve and Vicki
2 kids
(Tweaked!!)
Old 04-30-2013, 09:38 PM   #8
amxpress's Avatar
What is the weight rating?
Prodigy
Old 05-01-2013, 05:24 AM   #9
Commercial Member
huntr70's Avatar
Almost 4000 lbs....3987 or something like that.
Steve and Vicki
2 kids
(Tweaked!!)
Old 05-02-2013, 12:37 PM   #10
I changed out the Chinese E rated junk on my last Sunnybrook for Goodyear G614s. Went from 80 PSI tires at nearly max load to 100 PSI with spare capacity. Never blew another tire. We have new 2014 Columbus 325RL and will change to G614s in a month. No damage from higher pressure tires (only a little stiffer) and no more damage when the junk blows up because the G614s are built right.
Rreilly is offline   Reply With Quote
