Old 03-22-2013, 02:54 PM   #1
Where to install a 50 Amp surge protector
I've ordered and will have installed a 50 amp surge protector with a remote monitoring device in my 2013 Columbus 320RS. This is not the portable surge protector, so I'm trying to figure out where to permanantly put it. I also order the remote unit and would like to put it in the closet where the washer dryer is. Has anybody installed this device or can offer suggestions?
Mr.z is offline   Reply With Quote
Old 03-22-2013, 03:08 PM   #2
ret2006's Avatar
On my Sabre 31 RETS I installed the Progressive 50A hard wired unit in the basement area behind a wall which was behind the converter and fuse panel. It is a very confined area but it needs to be close to the converter and where the electrical line comes in from the back of the trailer.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 03-22-2013, 06:08 PM   #3
3 Happy Campers's Avatar
Ditto on our Sierra 356RL.
You’ll need a pair of bolt cutters to cut the cable.
*** Make sure you have the shore power unplugged before you cut into the main cable!!!!
Name:	50 Amp Surge Guard.jpg
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 03-24-2013, 10:33 AM   #4
We also have a 2013 320 RS. I installed the 50 amp monitor next to the battery cut off switch in the forward department just because I didn't think I needed tomonitor it inside the unit. The search protector is mounted behind the wall Where the monitor is in the forward pass through compartment. It's a very nice location and everything works well & it is out-of-the-way.
Mark/Jeannie & Chaps (Aussie)
2013 Columbus 320RS
2012 Ford F350 KR diesel. Hensley BD3 Air Suspension Hitch
Chaps is offline   Reply With Quote
Old 03-24-2013, 10:56 AM   #5
Denver, CO
garbonz's Avatar
Close to the inlet plug or the breaker box and you don't have to cut the wire. You get a short piece at the hardware store and that way can remove the surge protector if you trade up
2017 Fuse 23T
Old 03-25-2013, 09:40 AM   #6
treaves's Avatar
Would you post a few pics?
treaves is offline   Reply With Quote
Old 03-26-2013, 09:04 PM   #7
Treaves-
Sorry I can't get you any pictures. Our RV is in storage quite a distance away from where we live and I won't be going there till next month. As I said in my post, the monitor is located close to the battery cut off switch. The surge protector is mounted Behind the wall where the monitor is located.
2013 Columbus 320RS
