Old 03-05-2013, 10:53 AM   #1
Where's the Woofer
Hi, can anyone tell me where to find the Bass speaker in a Sabre 31-RETS. It sounds as though it is located under the stairs, if that is the case how can I get access to it?
ex-egll
ex-egll is offline   Reply With Quote
Old 03-05-2013, 11:11 AM   #2
TURBS's Avatar
ex-egll
Mines under the stairs.
Through the basement there's a removable panel.
Turbs
Old 03-05-2013, 11:34 AM   #3
It's actually called a subwoofer. Mine is under the stairs too. If I crawl in my garage I can see it.
Old 03-05-2013, 11:49 AM   #4
Thanks, guess the basement needed a clear out anyways!!
Old 03-05-2013, 12:02 PM   #5
TURBS's Avatar
Btw welcome to the forum!
Turbs
Old 03-05-2013, 04:31 PM   #6
Unless you have the optional electrical fireplace where most Palomino RV's place the sub-woofer. No fireplace, then behind the access door leading to the area under the stairs.
Myron & Delores
2005 GMC Sierra 2500HD
(2WD, Extended cab, 8' box)
2013 Palomino Columbus 320RS
53Oliver88 is offline   Reply With Quote
Old 03-08-2013, 11:53 AM   #7
Again thanks for the replies (and welcome!). We have the fireplace, and it has been put to good news here in GA in the evenings!
Still trying to find the access panel in the basement. If I open the storage there appears to be a fairly permanent divider separating the storage area from anything rear of it. Will keep looking as I clear more stuff out.
Old 03-08-2013, 05:26 PM   #8
ret2006's Avatar
ex-egll
Under the control panel door above the fuse panel as you walk in the door on my 2012 Sabre 31 RETS.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 03-09-2013, 10:49 AM   #9
Thanks ret2006, looks like there is a change from 2010 to the 2012 model. Above the fuse panel door I have a wood panel. If I pull the fuse panel / converter out, there is just an empty space above it (behind the wood panel). Back to the hunt, pretty sure it's under the stairs, just need to find the access.
