05-21-2013, 12:18 PM
Whole System Water Filter
I have a 2012 Sabre 32RCTS with the water filter installed from the factory in the pass thru area. What a terrible place to put it (IMO). I'm thinking of moving it into the water bay area. There's about 14" of empty space just below the hose inlets where it should fit nicely. I realize that the water bay wall is thin (but so is the wall where it's currently mounted) so I would reinforce the back with some plywood. This would allow easy access for changing out the cartridge and keep any spilled water contained within the water bay ... and I wouldn't have to unload my chairs and stuff to get at it.
Has anyone done something similar or do you see any problems with this?
2012 Palomino Sabre 32RCTS-6
2012 Ford F-250 Super Duty Fx4 6.7 Powerstroke
16K PullRite SuperGlide
Air Lift LoadLifter 5000 Air Bags
05-21-2013, 12:33 PM
I have a sabre as well and its a little rough for a young guy like me to get in there and switch it it out but I do.
I guess having to only do it three times a year hasnt been enough bother for me to move it else where.
I dont see an issue doing what you want.....
carry on !
please post up pics of the move of your water filter.
turbs
I also have a 32 RCTS and I agree It would be better if it were mounted elswwhere but, I'm not pcturing the "water bay" area you speak of.
I can reach mine with out removing anything through the side if I stand on a stool, but it is hard to remove it wothout spilling water.
btw. I installed a pair of by-pass valves to make winterizing easier.
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
05-21-2013, 01:21 PM
I removed mine from it's difficult to reach factory location, and just went with an outdoor stand, which I stick in the ground next to the TT. Run the hose from the CG spickot to the stand, through the filter, and then through a 5' piece of white hse into the TT. When I know that I'm going boondocking, with no spickot available, I just leave the entire stand, filter, and hose home, and take my refillable water bladder instead. Takes up abut the same space, and I dont have to carry both, except on trips where I know that I will (or might) need both!
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
05-21-2013, 07:10 PM
The "water bay" I'm talking about is on the driver’s side which is accessible when you open that side of the pass thru. That's where the connections for all the water hookups are ... fresh, city, black tank flush, winterize. I am contemplating installing the filter below these with the bottom just far enough off the floor to allow for the canister to be removed. I'm not as young as Turbs and can't bend myself around everything to get to it!!!
05-21-2013, 07:18 PM
That makes sense...in fact...I've seen them installed there on other (non-Sabre) models. Let us know how it comes out.
Cathy & Jeff
Midland, Michigan
05-21-2013, 08:03 PM
I own a Cedar Creek Silverback and mine is mounted just inside my access door. Maybe this will help you. Here is a pic of mine. Good luck
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
05-22-2013, 06:26 AM
I never installed the filter I received with my rig. I use an inline filter at the spigot that does a much better job of removing icky stuff from the water without affecting the flow. The factory filter might do a good job of removing dead bugs and such, but does nothing to remove the chemicals and toxins.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
05-22-2013, 06:32 AM
On my columbus, trhe water filter is mounted in the water bay as well. Make sure that you put something behind it when you mount it, Mine pulled out the first time I went to replace the filter and had to put a piece of plywood behind it to mount it into. Now it is in there sturdy.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
05-22-2013, 06:45 AM
Our Whole house filter,use any standard element you want in regards to (Media). Youroo!!
05-22-2013, 07:22 AM
I like your idea. Much better than monkeying around with the filter replacement in tight quarters. Mind if I ask what in line filter you are using?
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-(20) 2019-0
05-22-2013, 08:43 AM
X2 with BombDoc
2012 F250 Super Duty
2013 Sabre 33CKTS
05-22-2013, 10:28 AM
Thanks for the picture kc8lvy. That's exactly what I'm wanting to do. It looks like a real clean installation with easy access and wiil contain any water spilled during filter replacement. I plan to reinforce the back with plywood. Also, I like having it on the inside. Now I just wish my pass thru was as empty as yours!!!
05-22-2013, 03:58 PM
I use a Camco RV inline filter from Camping World. It not only removes stuff like sand & dirt, but it also cleans up the water from chemicals and nasty stuff like that. I only use one a season.
Amazon.com: Camco 40045 RV TastePURE KDF Water Filter - 2 pack: Automotive
Prodigy
05-22-2013, 04:28 PM
That pic was on my dealers website before we bought it. It now is full!!!!!
I am going to buy some totes to try to keep it neat.
Good luck with your project.
