Old 04-17-2013, 09:22 AM   #21
Thanks for the heads up Byron. I have not tried brute force yet out of fear of permanently bending the aluminum. I may try using a Dremmel to slightly notch the screen at the bottom to fit around the crank.
SargeW is offline   Reply With Quote
Old 04-17-2013, 09:51 AM   #22
Send a message via ICQ to ByronCR Send a message via AIM to ByronCR Send a message via MSN to ByronCR Send a message via Yahoo to ByronCR Send a message via Skype™ to ByronCR
I totally understand the fear of bending the aluminum. I had the same fear. I remembered having the same difficulty with the screens in my Travel Trailer, so I checked the screens during my PDI on my Columbus. I actually had complied a PDI checklist from 3 different PDI lists I got off of this forum and one of them said something about windows and make sure they open all the way which caused me to check all the screens as well.
Hope your able to get it all figured out.
Byron R
2013 Columbus 295RL
2006 F350 6.0L Crew Cab LB SRW
ByronCR is offline   Reply With Quote
Old 04-17-2013, 09:55 AM   #23
I will post a pic when I get one trimmed out.
Old 04-17-2013, 07:57 PM   #24
Well I took the "force it into place" method that Byron suggested. Most of the screens were forced into the windows, causing a noticeable "arc" at the bottom. The question now is will they stay in after the trip home on the freeway.
On one of the side screens I used a Dremmel to slightly notch the screen where the crank sits. It helped a little, but to get a truly ideal fit, the screen would have to be notched along the entire length of the opening mechanism, which is about 3" long.
For now I will wait and see. The saga continues....
Old 07-28-2013, 10:33 AM   #25
Denver, CO
garbonz's Avatar
update please???
2017 Fuse 23T
Old 07-28-2013, 11:48 AM   #26
Unfortunately I am still fighting with the screens. Force seems to be the only way to seat the screens, and then you take the chance of warping one. One of my rear screens over the sofa is being replaced by FR due to the frame just warping and not being able to stay attached to the frame. Just a poor engineering design.
Old 07-28-2013, 02:26 PM   #27
after inspecting my screens, the only suggestion I have is to basically disassemble the screen (remove corner pieces) and trim the heighth of the sides. Then reassemble. I would definitely tell / make the dealer do this.
Byron R
2013 Columbus 295RL
Old 08-01-2013, 12:42 PM   #28
Screen on my Palamino 32RCTS
I picked up my Palomino Sabre 32RCTS 2 weeks ago. The screen issue was on my list to check since I had read an earlier post about this issue. Everyone of my screens that have a turn knob have a half circle cut into the screen frame to accommodate the knob mechanism. Was the same on my Jayco travel trailer I traded in. I know the Sabre & Columbus are made in different factories, but give me a break. What good are screens that wont seal. As I said, this has been posted previously. Maybe Christopher Columbus can chime in.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 08-01-2013, 02:01 PM   #29
BuckeyeChuck's Avatar
I would send Chris. Columbus a PM explaining your problem.
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
