Old 04-13-2013, 10:57 PM   #1
Window screens?
Here is an issue that has me confused. We picked up our 320 yesterday at the dealer after various technical problems getting it ready. No worries, most of it was out of the dealers control.
So today we get inside and start getting things ready for our first trip. While sitting on the rear sofa talking to the DW, she made an observation. "Hey, whats wrong with that screen?" Inspecting the window screen on the rear window, it was obiviously askew. After close inspection of not only that screen, but ALL of the screen, none of them fit snugly in the window frame.
After fiddling with it for a few minutes the cause was clear. Any window that had any kind of crank or latching device at the bottom of the window caused the screen to not sit flush into the frame. While most of the misfitting screens were hidden by the window treatments, significant gaps were obvious all around the window edges.
The obvious fix would be to grind or cut the bottom of the screen in the area of the latch to allow the screen to fit snugly into the frame.
But the question is, is it just my unit that has this issue? Have any other Columbus owners noticed this problem? Is this a manufactuering issue, or just the screen on my unit?
Thanks for input. I will call the dealer on Monday and see what he says.
SargeW is offline   Reply With Quote
Old 04-13-2013, 11:00 PM   #2
Fulltime family RVer
Mind taking any pics to show what you're seeing?
Old 04-13-2013, 11:17 PM   #3
No prob, I will get a few in the morning. The easiest way to describe it is the crank for the window, which is in the center bottom of the frame, sits too high to let the window screen seat firmly against the frame. I will post up some pics tomorrow.
Old 04-14-2013, 11:38 PM   #4
Here are pics of the problem window screens. It centers around the fact that the window cranks in the center bottom of the windows are preventing the screens from seating in the frames.
The obvious fix is to either grind the bottom of the screens to allow the screen to fit into the opening without hitting the crank mechanism, or lower the cranks to allow the screens to fit normally. See what you think.
ID:	28015   Click image for larger version
ID:	28016   Click image for larger version
ID:	28017   Click image for larger version
ID:	28018   Click image for larger version
ID:	28020   Click image for larger version
Old 04-15-2013, 12:49 AM   #5
Howdy Sarge!
I just went around and cleaned all the windows inside, and I had the same problem! You really have to play with them and pound them on pretty hard, and they still kinda ride the crank, causing it to bend alittle at the bottom. I would be interested in what you find out. Maybe Christopher Columbus could chime in also!!
Larry & Kerry Jackson
2012 Ford F250SD
2013 Columbus 320RS
Kerryj is offline   Reply With Quote
Old 04-15-2013, 01:10 AM   #6
That is what I am hoping. If this is a manufacturing goof up, then someone needs to step up. The DW is highly allergic to bug bites, and having gaps around all of the screens is totally unacceptable. I will post up when I talk to the dealer tomorrow.
Old 04-15-2013, 03:34 AM   #7
SYE
SYE's Avatar
I do not remember seeing gaps on mine but I will check when I get it back from repair this week. I have not had the windows open a lot so I will have to look.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
Old 04-15-2013, 07:49 AM   #8
treaves's Avatar
Ick. Something seems to be wrong in those photo's!
treaves is offline   Reply With Quote
Old 04-15-2013, 08:56 AM   #9
great white's Avatar
Seems to me the quick "no cutting" solution would be to mount the crank mechanism on the other side of the aluminum frame so the screen can sit flush to the frame. Two screws and it's done.
It's always hard to tell from internet pics though....that may not work out.
My flagstaff classic has the crank mechanisms in the window frame similar to what I suggested, but it's not a "scissor" like arrangement like yours. It's like a geared lever.
Regardless, I still had to tweak and adjust my screens to fit flat also. No filing, just a little bend/tweak/tighten session. They're all pretty light and cheap...
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
Old 04-15-2013, 09:13 AM   #10
tugboat369's Avatar
some body has to see that and passed it?
Camping from 2008, Life member Good Sam / KOA / iRV2
2014 Columbus 320RS
2011 Ford, F250, 6.7D, SRW
tugboat369 is offline   Reply With Quote
