Old 10-15-2018, 04:14 PM   #1
Duramax2017's Avatar
Winterise
What is the best and fastest way to winterize your ice maker on the fridge. I guess there is a couple different ways of doing it.
Duramax2017 is offline   Reply With Quote
Old 10-15-2018, 11:26 PM   #2
I'll be doing this for the first time this year:
See if there is a drain where the water supply goes from normal size to small diameter. Open valve, blow with air or pump with pink stuff. Then shut off drain, pump pink stuff. (If there is a water dispenser, first use it until pink stuff comes out.) and make ice cubes until they are pink.
2017 Riverstone 38FB Legacy
2018 F450
LegacyFB38 is offline   Reply With Quote
winter
