10-09-2017, 10:24 AM
Winterizing
Anyone know what those 2 pipes are for underneath RV? I’m thinking they’re gonna have to get drained?
10-09-2017, 10:50 AM
Scoundrel
Yes, low point drains. Unscrew the caps and let the water out, then plug again before you put antifreeze in.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
10-09-2017, 11:03 AM
Thank you
10-09-2017, 03:17 PM
Make sure after you unscrew the caps you open all the faucets to drain the water.
10-16-2017, 11:25 AM
Does the city water hook up need antifreeze or isn’t that anything to worry about?
10-16-2017, 11:46 AM
Scoundrel
I'm certainly no expert, but on mine I hooked up a short piece of hose (two feet?), got a funnel and poured a small amount of anitfreeze into the city water connection. Also, if you have an outside shower don't forget about that.
10-16-2017, 12:02 PM
There should be a check valve on the city connection to just adding water without pressure won't really do anything. If you pull out the filter screen you should be able to push the check valve with the water pump on and let antifreeze flow out. You may get wet.
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
10-16-2017, 12:23 PM
Scoundrel
Thats good to know. Thank you.
10-16-2017, 12:24 PM
Agree. You can't pour antifreeze into the city water connection. You can pressure fill it or allow it to pressure outflow as described here.
You an pour antifreeze into the fresh water tank filler but DON'T! It's very hard to rinse out of there. Since you can and should drain the fresh water tank, there is no reason to put antifreeze in there!
2016 FR Forester 2401R
Towing 2014 Honda CR-V
10-16-2017, 12:29 PM
That’s simple enough. Thank you
