02-15-2015, 10:58 AM
Winterizing
I have a quick question. I put antifreeze in my lines but forgot one thing I guess because I never use it. But I didn't open up my outside shower head up to run it out. Will it be ok? Of freeze and bust? I have never ran water through it
02-15-2015, 11:08 AM
If there is any water in the line, faucet or shower head, it will freeze and probably damage it.
Fonzie
02-15-2015, 11:17 AM
Odds are good you have water to the faucet at least, there may well have been some leakage into the shower line and head.
It is possible that some AF may have leached in to that area but is is most likely very diluted.
02-15-2015, 11:21 AM
You must live in a Cold location? Unless they tested your system with (Air) someone put water in it! To late now,you will know in the future. Drain the Pink come Spring and (Test with Air) that way you will NOT have WATER to mop up where your leaks are! (30 PSI Regulated Air Pressure is Plenty for this TEST,and you can Hear it! Youroo!!
02-15-2015, 12:46 PM
Yes I live in southern wv. It was -2 last night. But one thing I hope that may help is all winter I have kept heat on 40. Last night put it up to 50. Just hope that helped
02-15-2015, 12:50 PM
Are you talking about keeping heat on in unit or do you store unit inside that is heated,if you store inside at 40 deg. don't worry about it!
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
02-15-2015, 01:00 PM
No it's outside. But keep heat on in the camper
02-15-2015, 01:06 PM
Sorry you might have a problem then.
2014 Forester 3051s
2012 Sonic toad
02-15-2015, 01:07 PM
You don't say what unit you have, but many models use plastic faucet assemble in the outside shower. If it froze, it most likely cracked. In addition to winterizing, I always remove all my shower heads just to be safe. Takes 1 min to reattach.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
02-15-2015, 01:12 PM
I have a solaire 267bhsk
02-15-2015, 01:21 PM
Go to lowes or HD and buy a roll of silver insulation Cut two pieces to cover your shower door. With the heater on you still might be okay.
Coachmen M/H
Concord
2018 / 300 DSC
02-15-2015, 01:38 PM
My guess if the temp dropped below 32 for any length of time the likely hood of that line(s) freezing increases. Not sure where you live but if you can get a heat source on it, flush it now with anti-freeze, otherwise deal with the issue when you open it up in spring.Cross your fingers.
02-16-2015, 09:50 AM
Got outside to check it yesterday and my outside shower head was cracked. But as far as I can tell that's all that it got. Warm all the way to that part
02-16-2015, 10:14 AM
Ret E-9 Anchor-clanker
I keep the silver insulation in place. Never remove. After the first antifreeze winterizing I just kept the antifreeze in there. In five years of camping I have never used it after the PDI test. It still has never leaked.
02-16-2015, 10:44 AM
Not sure of your set-up, but can you get heat in that compartment, like a 60 watt bulb, just to minimize the damage of freezing the other components.
02-16-2015, 04:43 PM
Yes I have done that. And everything else does have pink in it
02-16-2015, 04:45 PM
It wouldn't have ever froze but I forgot all about it and never put any pink in the outside shower
02-22-2015, 10:42 AM
Well we have hit 40deg here and I went out to the camper with a jug of pink stuff. I used my pump and when I turned on the outside shower pink stuff came out. I did have a very small drip when in the on position. But in the off nothing. I cut both the cold and hot off. Then watched and jug of pink stuff and never lost any. It stayed the same level for over 5 mins. So the damage is very minimal as far as I can tell right now. Bet I won't forget that next year.
