Old 01-05-2015, 12:59 PM   #21
Kaadk's Avatar
Originally Posted by slipf18 View Post
Yup, a pizza stone works...but they're round and the oven space is square...so, we use an UNGLAZED ceramic tile. Bada bing!!
We've got a square pizza stone that was given to us for our wedding, so they're not all round. Not that I use it in the TT, just saying that they aren't all round.
Old 01-05-2015, 01:10 PM   #22
Always Learning
We had a good Pampered Chef stone that was sitting in our "yard sale" pile because it was never used. It now lives at the bottom of our camper oven. Over the holiday, my wife made cinnamon buns and "filling balls" (aka stuffing aka dressing) for Christmas.
They were all perfectly cooked.
Old 01-05-2015, 02:01 PM   #23
Mddle of the Rd Extremist
MeepMeep's Avatar
X2....
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 01-05-2015, 04:20 PM   #24
BamaBob's Avatar
Originally Posted by MeepMeep View Post
X2....
Make that X3 ours is identical to yours MeepMeep!
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 03-15-2021, 09:19 PM   #25
You need a couple of inches between each side of the pizza stone & oven to allow heat to circulate
mmarken is offline   Reply With Quote
Old 06-08-2022, 01:57 PM   #26
Sunseeker 3010DS
Yes works great any size stone helps a lot. Mine is round and
Works great.
slamac is offline   Reply With Quote
Old 06-08-2022, 02:10 PM   #27
jeff64's Avatar
However you do it, I found an oven thermometer, a gotta have item
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 06-08-2022, 02:25 PM   #28
Rhumblefish's Avatar
Goodness gracious, a blast from the past. Zombie post from 2015 reawakened! All good responses, and still holding true.
Biggest takeaways are:
1. pizza stone is a great addition to the stove: not only does it help cook a great pizza (even frozen), but it also evens out the heat, and acts as a heat battery to mitigate the effects of opening and closing the oven door.
2. You don't need one that says PIZZA STONE (though you also don't want glazed or decorative inclusions in a tile from Home Depot). Another forum I am on loves the PIZZA STEEL (which works the same way, just metal). Don't burn yourself!
3. You need a little room around the stone itself for circulation, AND we've found you can cook at a slightly lower-than-marked temperature. An in-stove thermometer is an easy addition to make sure your temps are on target (we have one that hangs from the grating, so it's not in the way).
4. The air bake sheets are a double layer, standoff cooking surface (like a multipane window) that provides some insulation from excess heat being migrated through the cooking sheet and into the bottom of your chocolate chip cookies. The way a pizza stone works is the EXACT OPPOSITE (to ADD even, controlled heat to the bottom of your pizza), so if you're using an airbake sheet, make sure you know what effect you're going for. Also, if your cookie sheet has a nonstick coating on it, you might consider not keeping it in the oven. They're designed for USE in a high temp environment, but that being used intermittently, not STORED in there (which may take a toll, like too much use of a non-stick pan).
Hope this helps. Buon appetito, and mange bene!
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
Rhumblefish is online now   Reply With Quote
