Old 05-29-2012, 09:54 PM   #11
Jeep4Two's Avatar
Originally Posted by DonG
The camper was parked.
Yes, I realize that but based on the wind I wonder if an lp flame on the parked trailer could have been a contributing factor (or the cause). A few hours parked on 12v would just seem safer and shouldn't be a drain on the camper or RV battery.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 05-29-2012, 09:55 PM   #12
Jeep4Two's Avatar
Originally Posted by Tee
And 12Vdc is very capable of starting a fire!!!
Also true but would seem less likely except in the event of a major failure, which may have happened.
Jeep4Two
Old 05-29-2012, 10:08 PM   #13
caper's Avatar
About 10 years ago while camping at the Lighthouse Campground at Rockport On a motor home went up in flames while parked at the campground. The fire department arrived with in 10 min. but all they could save was the frame. With luck they were parked about 6 feet away from a 200lb propane tank. The firemen kept the large tank cool. It is amazing how fast a RV unit will burn. It does not matter if you are towing or parked if there is a gas leak and a source of ignition you will have a fire.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
