I can not take the credit for this checklist, it was done by Mark Polk but I was looking for a list to start with to get mine ready for the season, so I figured I would share with everyone.
Spring Preparation Checklist:
After a long winter sleep we finally decide that spring is here for good and it is safe to prep our RV for this years camping season. Now that the decision is made we need to figure out what steps to take to prepare the coach and the chassis for camping and traveling. If you’re like me, you want to have some type of logical sequence to follow rather then haphazardly checking the unit out. This is a simple checklist to use so that nothing is overlooked. I prefer to do the majority of spring preparation myself. If you’re more comfortable having someone else do it contact a reputable RV dealer and schedule an appointment to have it done.
- Depending on how your unit was winterized it will need to be de-winterized.
- Sanitize the water system.
- Inspect for water leaks. A quick and easy way to test your RV plumbing system for leaks is to turn the 12-volt water pump on when there is water in the fresh water holding tank. Once it pressurizes the system and turns off it should not come back on until you open a water faucet. If the pump does come on sporadically, even for short periods of time, water is leaking somewhere.
- Check the operation of the toilet
- Remove any tape or protective covering that may have put over LP gas vents or outside vents to keep insects or rodents out. Check any mousetraps you may have put out. Open all doors and compartments and check for rodent intrusion and water damage.
- Wash the unit thoroughly. This is a good time to inspect the roof and body seams, and window sealant for cracking that would allow water to get in. Consult a dealer for sealants compatible with these materials.
- Inspect the operation of the awning and check the awning fabric. Clean the fabric and let it dry thoroughly before rolling up.
- Inspect the tires for signs of dry rot and wear. Inflate all tires to the recommended COLD tire pressure. Check the lug nuts for proper torque.
- Lubricate all hinges and locks with spray lubricant.
- Inspect and clean the RVs interior.
- Plug in any appliances that you unplugged for storage and replace any dry cell batteries you may have removed. This is a good time to put new batteries in items like smoke alarms.
- Test the operation of the carbon monoxide alarm, LP gas leak detector and smoke alarm.
- Check the fire extinguisher. Be sure it is fully charged.
- Reset any breakers you may have turned off. If you removed any fuses for storage re-install them.
- Clean or replace air conditioner filters if it wasn’t done prior to storage and remove any covers that were put over air conditioners.
- Open vents and windows and air the unit out.
- If you removed the coach and chassis batteries for storage install them. Whether they were removed or not check the electrolyte levels, clean the terminals and clamps, and check the charge level in all batteries. Recharge batteries as necessary.
- Check the operation of the electric steps if applicable. Lubricate step mechanism.
- Test the operation of the hydraulic jacks if applicable. Check hydraulic fluid level.
- Test the operation of the back up camera and monitor if applicable.
- If you didn’t change the oil and filters in the generator prior to storage this is a good time to do it. Inspect the generator exhaust system for damage prior to starting. Start and run the generator for one hour with at least a half rated load on it. Consult the generators owner manual for load ratings.
- Turn the generator off and plug the unit into shore power. Turn the refrigerator on in the electric mode. Allow sufficient time to cool and check for proper operation.
- Check all 12-volt interior lights and accessories.
- Test the monitor panel for proper operation.
- Check the operation of slide outs if applicable.
- Check the remaining 120-volt appliances for proper operation.
- Test the Ground Fault Interrupter (GFI) for proper operation.
- Turn the refrigerator off, leave the doors open and allow sufficient time for it to get to room temperature so it can be checked in the gas mode.
- Before I use the LP gas system I have a leak test and gas operating pressure test preformed. A qualified technician with the proper equipment should do these tests.
- Once this is accomplished turn the LP gas valve on and check the operation of all LP gas appliances. Be sure the water heater is full of water before testing the water heater. If a gas appliance is not operating properly have it inspected by a qualified technician. Insects are attracted to the odorant added to LP gas and build nests that can affect the appliance from operating properly.
- If your unit was in long-term storage and you didn’t change the engine oil and filter prior to storage this would be a good time to do it
- Check all fluid levels in transmission, power steering, engine coolant, windshield washer and brakes. Consult vehicle owner’s manual.
- Start engine and check for proper readings on all gauges. Check for proper operation of dash air conditioner.
- A full chassis lubrication should be preformed if it wasn’t done prior to storage.
- Check the condition of windshield wiper blades replace in necessary.
- Check the operation of all chassis lights.
- Check to see that your inspection / emissions sticker is up to date.
- In addition to this if you have a pop up or travel trailer the wheel bearings and brakes (if equipped) should be inspected at least once annually. Inspect any canvas for dry rot and tears; inspect all hitch work and coupler for damage. Inspect the breakaway switch and pigtail for proper operation.
This list is not all-inclusive, but it seems to work for me. Now for the fun part, load your clothes, food, and personal belongings, hit the road and have fun exploring this wonderful country we live in. Happy Camping
