Forest River Forums
Sunline User Photos
Old 02-24-2010, 05:34 PM   #1
Red face it's cold these days
Would anyone know whats going on with my furnace. I own a 2007 flagstaff 5th wheel and one minute it's working fine and the next it turns on for 20 seconds, blows cold air then turns off. My tanks are full and there aren't
any blown fuses. Can someone help????
johnnyg is offline   Reply With Quote
Old 02-24-2010, 07:45 PM   #2
flyrotor's Avatar
Is it plugged into shoreline or on batteries? If on batteries, are they fully charged? If not charged, the heater will cycle then shut off while there is still enough power to shut off the electric valves.
If you are plugged in, then I have no solution, maybe someone else can pop in.
2011 Dodge 2500 CTD, Crew Cab, 169" WB, 6-speed man
2008 FR Wildwood 23 BHLE
Nights camped in 2011:20
Nights camped in 2010: 21
flyrotor is offline   Reply With Quote
Old 02-24-2010, 07:48 PM   #3
Do you hear it clicking the igniter? Air intake blocked? Air in your gas lines?
aintgotnun is offline   Reply With Quote
Old 02-24-2010, 07:52 PM   #4
It is possible you have a bad circuit board.
Hokiehall is offline   Reply With Quote
Old 02-24-2010, 07:54 PM   #5
grhodes50's Avatar
I had a similar problem with a previous tt. It would run for a minute or so then cycle off, then do it all over again. It turned out to be my regulator at the tanks. Cheap and easy fix. I don't know if that's your problem but you might check it out.
Gary & Trish
2011 LaCrosse 303 RKS Touring Edition : 2007 Flagstaff 206ST MAC Series
2010 F-250 XLT : FX4 : CC : SB : 6.8L V-10 : 4/10 Gears
Winter 2011/2012 - Hibernating
Old 02-25-2010, 05:12 PM   #6
i appreciate all the replys, i'll start trouble shooting. however as far as the regulater i asume it's working properly because the stove and the water heater are working fine, regardless, thank you all.
Old 02-25-2010, 05:31 PM   #7
grhodes50's Avatar
When my furnance was acting up the stove and water heater worked just fine as well. I was told by the service manager at my dealer the bad regulator didn't effect the stove and hot water tank the way it does the furnance.
If I remember correctly he told me the furnance was not getting enough gas and that was why it would shut off. There was however enough gas getting through to allow the pilot to light and start the burners, just not enough to keep them going.
All I really know is the new regulator at the tanks did fix the problem.
Hopefully someone on here can explain it better.
Gary & Trish
Old 02-25-2010, 07:22 PM   #8
NWJeeper's Avatar
Might take a look here for help on troubleshooting
Ed & Wendy
www.nwjeepn.com
Old 02-25-2010, 07:38 PM   #9
after alittle reading its looking like the module board is the culpret. I thank you all.
Old 02-25-2010, 09:07 PM   #10
NWJeeper's Avatar
Ask your dealer about a Dinosaur board instead of OEM (unless you are under warranty). Dinosaur Electronics makes excellent boards and are my first choice over OEM if one fails.
Ed & Wendy
www.nwjeepn.com
copyright 2006 - 2010
Close [X]
