08-17-2011, 01:02 PM
Not sure what they are called....
I recently purchased a 2009 Silverback 32RL but the dealer I bought it from did not know how to turn the front hitch or cap lights on. (Not sure what these are called). Can someone help point me in the right direction?
08-17-2011, 01:17 PM
Moderator
Are you referring to a scare lite ?? There should be a toggle switch on the bottom of the light.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
08-17-2011, 01:21 PM
not sure what they are called. On my last 5th wheel, there was a light at the king pin that had a switch. This 5th wheel has two LED lights built into the front cap but I can not find a switch and neither could the dealer....LOL.
08-17-2011, 03:39 PM
too fast turbo sled
On my sabre the switch is mounted next to the electric jack switch
On the bulkhead under 5th hitch
08-17-2011, 03:50 PM
My jack switch is in the side bin. There is a switch there that looks like a light switch and when I turn it on, nothing happens that I can tell.
08-17-2011, 04:04 PM
too fast turbo sled
Try checking to see if there's power at the switch.
if not you might have a blown fuse.
I am sure that that is the switch for your docking lights.
The switch could be bad too. Or the wiring up to the l e d lights.
08-17-2011, 04:19 PM
too fast turbo sled
also led lights don't generally "blow" out .
08-20-2011, 11:36 AM
too fast turbo sled
just curious did you find anything on your docking lights ?
08-20-2011, 11:52 AM
I assume this is a fifth wheel? So the light under the overhang near the hitch is controlled by a switch on the light itself. Same for all of this type of lights on the outside. As for the two BIG round lights up high, they are called scare lights and there will be two switches inside on the control panel that turn them on/off.
08-20-2011, 12:03 PM
too fast turbo sled
He is pretty sure he has found switch . but may or may not have found out why they are not working .
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 556 |
| 97 members and 459 guests |
| 2011sv264, 2lvrvn, Adony, adp1326, armcor02, bidesheng, Bigmatt, bjlowe, blaisrv, bmcgee, Buffalohunter, bumper, bush, Cccross3, COcamper, dashonthedash, Dave_Monica, daw592, DDC, ddemme, DeeMax, DonG, dunnnc, Fire Instructor, firemanrod, Frank4, Ggantilla, gimp425, grhodes50, Hilgy, hjmiberry, House97, Hydrothunder, Iggy, itat, Itsthetwoofus, J McClure, J R, JamesR, JDWeir, jjhwisconsin, JJL, jking, JoeR, jsutherl, jtstromsburg, J_King, Kirby, klucas, kwjeepxj, majag86, Margaret, Marsh707, mbrwr, meatguy, Mnflyboy, Murray10, mwilson949, myredracer, NO3putt, OffPavement, papamcgown, partime, patov6, pg_rider, Phil57, PHS79, punkaccountant, ret2006, rgfenner, RiverratII, rkswyo, RRkevin, rwhmtnfolks, sandys, sbond, Scooter2, sfrye5853, Smithee, snackage, Sparky44, sprayking, SpringerPop, steeleshark2, sundawg, Taranwanderer, tentcamper1, Terier, thehamguy1, troyt, tsmcmillen, VinceU, wagon52, Waterfowlwarrior, WestCoastRV'er, Whiteknight, wingriders |
| Most users ever online was 1,025, Today at 01:04 PM. |
