Old 03-24-2016, 02:42 PM   #1
Just A Member
EDABEUT's Avatar
RV Model Numbers
I was told that the numbers in a RV model number are the length of useable interior floor length. IE mine is a 297RLDS so the interior floor
length should be 29'7" long. The overall length is 35'2". Can anyone confirm if this is correct ???? Just curious.
Ed & Brenda
2015 Coachmen Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
EDABEUT is offline   Reply With Quote
Old 03-24-2016, 02:43 PM   #2
BandJCarm's Avatar
Absolutely not.
Model numbers do not equate to length. It would be nice if they did. But they do not.
They may, in some instances, be close.........
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 03-24-2016, 03:04 PM   #3
Rupkin2's Avatar
From what I have picked up through the years is:
if the model number has only 2 numbers ie. 28RK then the 28 is the length of the box.
If the model number has 3 numbers ie. 280rk then the 280 is liveable square feet, I think this also includes the slides.
This is my understanding to date
Oh, one more thing, it should be noted that these numbers are not totally accurate either
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
Old 03-24-2016, 03:17 PM   #4
Oaklevel's Avatar
Some model numbers mean something some model numbers mean absolutely nothing it just depends.............
So not advisable to put money on any of them....
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 03-24-2016, 03:54 PM   #5
Mr. Dan's Avatar
X2 -- Remember "measure twice; cut once"!
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 14; booked = 28
Old 03-24-2016, 04:10 PM   #6
John
My Rockwood Mini Lite 2503S (same as Flagstaff Micro Lite 25KS) has a box that's 22ft long and and overall bumper to hitch of 26'-9". So I don't think either of those theories is correct. Since the Mini Lite comes in several other floor plans (2502S, 2504S, 2505S), you might think they're all 250 square feet, but that doesn't work, either. The basic box would be 22 x 8 = 176 square feet, meaning the slide would need to be 3 ft wide x 25 ft long, or 4 ft wide by 18 1/2 ft, or 5 ft wide by 15 ft long, which it isn't.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
Old 03-24-2016, 05:50 PM   #7
Just A Member
EDABEUT's Avatar
Thanks - I didn't think it sounded right when I heard it either. Was at a RV show and over heard someone comment on the model numbers. On the other hand it looks like on at least some of the models the letters seem to make more sense. RL=rear living room BH=bunkhouse etc. My TT is in for warranty work so I could not measure it to check.
Ed & Brenda
Old 03-24-2016, 06:25 PM   #8
Moderators' Assistant
bikendan's Avatar
One thing that you can pretty much guarantee, is that the actual trailer length will be longer than the numbers in the model number.
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 03-24-2016, 08:54 PM   #9
(RV Manufacturers don't exactly believe in truth in advertising!)
Old 03-25-2016, 06:25 AM   #10
World Wide Wanderer
wahoonc's Avatar
Model numbers are just that... numbers. Sometimes they mean something specific other times they are simply an identifier. They may give you the ability to compare between similar units by the same manufacturer. My Coleman CM16FBS was 16' on the floor. My Airstream Sovereign International 31' was only 26'-9" on the floor.... go figure.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is online now   Reply With Quote
modifications
