Old 06-11-2019, 05:36 PM   #1
Scoundrel
HangDiver's Avatar
Uptis airless tires
Interesting new concept to be used by GM. https://michelinmedia.com/michelin-uptis/
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 06-11-2019, 05:59 PM   #2
Now a "Top Member"
EdJunior's Avatar
How do I get my Raised White Lettering??
Interesting, and I've seen the concept for these for a while, but have yet to see them on the road. I wonder how the general public will take to it, despite its advantages.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
Old 06-11-2019, 06:09 PM   #3
wmtire's Avatar
Seems to be a variant somewhat of Michelins Tweel.
The balancing problem is what has been keeping the Tweel from coming on passenger vehicles and trucks.
I wonder if this can get past that.
2011 Flagstaff 831 RLBSS
Old 06-16-2019, 04:17 PM   #4
Retired Old Fart
dward51's Avatar
But where do you put the TPMS?
(Sorry, could not resist )
Actually great idea, but ugly as sin to look at.... Here is an interesting thought. So how would you de-rate the LT truck version for trailer use to account for the sidewall softness? There is no sidewall on the Uptis. I doubt they will make a ST version as there may not be enough volume. I also suspect the price will be shocking as well, although I did note in one video the tire was stamped as Made in U.S.A.
Just the 2 of us in a...
"Currently between trailers"
Sold the 246RKS in 2023
dward51 is offline   Reply With Quote
Old 06-16-2019, 07:47 PM   #5
Looking at the "structure" I'd be concerned about flat spotting after the vehicle sits for even short periods.
In a conventional tire the load support is a cushion of air with a relatively small containment structure (tire body and tread). This concept relies on the structure to carry load and remain flexible at all times. Sitting in one place, especially on a sub zero day?
So far the only place I've seen tires/wheels like this used is on low speed, high puncture hazard areas like Land Fills, Salvage Yards, etc. Essentially vehicles that have speed requirements limited to around 35 mph or less. Solid fill for tires has been around for years and both balance and heat have always been the bugaboo to getting them on the road at highway speeds. Solid fill has worked pretty good on kid's bicycles though.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
tire, tires
