Old 07-15-2013, 07:34 AM   #21
Rugged Brown's Avatar
Looks like a nice idea OC, not sure I would do this though. I always use 6 x 6 blocks under my landing pads and jacks. It would be hard and impractical to permanently fasten them. My sense is that the less you extend the jacks, the better the stabilization. This thread is entertaining. Are you sure you guys aren't Hatfields and McCoys?
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 07-15-2013, 07:52 AM   #22
Words with meaning more than most could imagine!
That's what is so great about specialized forums like this one. Great ideas to spawn more ideas and modifications working towards solutions that fix problems and enhance convenience.
Keep those ideas rollin!
2014 Flagstaff 832IKBS Travel Trailer
2012 F150 EcoBoost (HD Payload & Max Tow)
Doering is offline   Reply With Quote
Old 07-15-2013, 08:03 AM   #23
Herk7769's Avatar
I like the composite idea too. Lighter, but maybe less rigid. An aluminum plate coupled with the composite will reduce the weight of the blocks I carry (in addition to the Lego blocks).
HAM CALLSIGN - KC3FFW
Old 07-15-2013, 08:11 AM   #24
The composite deck boards are not all that light. Coupled with an aluminum plate heavy enough to take the load, the combination may not be any lighter than plain old 2x8 blocks.
bakken is offline   Reply With Quote
Old 07-15-2013, 08:13 AM   #25
Herk7769's Avatar
Sigh, good point...
Old 07-15-2013, 08:18 AM   #26
Looks like a nice idea OC, not sure I would do this though. I always use 6 x 6 blocks under my landing pads and jacks...
Also considering an pc of alum tread plate on a Lynx block. If the Lynx block gets damaged, easily replaced.
As I use homemade type JT Strongarms, the taller the triangle, the better.
Old 07-15-2013, 09:16 AM   #27
Fulltime family RVer
Originally Posted by OldCoot View Post
Would like to find some of the plastic composite deck boards wide enough to use instead of wood, but so far have only found it 5.5" wide.
What about 2 layers of composite boards running perpendicular to each other and screwed/glued together?
ependydad is online now   Reply With Quote
Old 07-15-2013, 09:36 AM   #28
Doh! Someone always comes up with the solution!
Old 07-15-2013, 10:35 AM   #29
If one layer is too heavy, 2 layers would be 2 x as heavy.
I will go with the alum tread plate and Lynx block. Light and replaceable. Laying the tread plate out in a few minutes.
Old 07-15-2013, 10:37 AM   #30
