Old 04-30-2014, 07:11 AM   #1
Rolling buckeye's Avatar
Another convert
Well, looks like I'll have a good head to head comparison in the gas vs diesel debate. DD just traded his king ranch , f250 on a 14 Laramie 3500,with the bigger hemi,crew,8'box,with 410 ,srw. Vs my 12 crew,cummins,8'box,with I think 373rear. Dealer told him,he should get almost the same mpg as the cummins. We'll see.....
Rolling buckeye is offline   Reply With Quote
Old 05-01-2014, 06:05 AM   #2
Herk7769's Avatar
Will be looking forward to a cost comparison.
I hope he keeps good notes.
Getting tired of 200 dollar oil changes myself...
HAM CALLSIGN - KC3FFW
Old 05-01-2014, 06:44 AM   #3
Hay Herk!!
Ya, we will see,good records?humm... Probably not , he will show better numbers ,just to mess with me. Supposedly,the gas has the upper hand,it will drop 4 cyl. when at cruzing speed. I saw it last night, it is the midnight gold ? Looks like brown,with a lot of metal flake. Vary sharp.
Old 05-01-2014, 06:54 AM   #4
TURBS's Avatar
Hmmmm $200.00 oil changes?
You should be able to double your mileage on oil life from a gas to a diesel as the 15w40 diesel oil has so many more additive packages to extend and still be a good viabt oil.
10 qts. @ 4.00 a qt
1 oil filter @ $8.00
1 fuel filter "caterpillar" "10,000 mile" service interval. "2 micron"
Subscribed to watch.
TURBS
Sabre owners united!
Old 05-01-2014, 07:00 AM   #5
Oakman's Avatar
Having used both a gas engine (8.0 V10) and diesel engine (6.4) for towing, the cost factor is no longer an issue for me. I love the power of a diesel but more importantly I love using the truck pumps when fueling up. I don’t miss the stress of being able to maneuver around the gasoline pumps.
Wow Herk, $200 oil change is high. I get my oil changed at the Ford dealership and it runs me $105.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-01-2014, 07:01 AM   #6
When the weather was so bad,I went to speedy lube.did not feel like crawling under trk. They did chance n lube,for $85 with conventional oil. Much shorter life than the delvac, I was using. Said they had the delvac,and would use for, $185. I run a lot of miles, and am trying to see which way is best.?
Old 05-01-2014, 07:08 AM   #7
Boy, I get Mobil 1 10-30 $26, and GMax charges $30 and furnishes the filter, grease job, air pressure and light check. Definitely will keep me old gasser.
Old 05-01-2014, 07:15 AM   #8
Herk7769's Avatar
Duramax needs 10 quarts every oil change plus filter.
Every other oil change is a very expensive fuel filter (whole thread devoted here to replacing the stock GM filter and body to use cheaper CAT fuel filters.)
We won't even talk about the Allison Transmission (it does have a spin on oil filter though).
Old 05-01-2014, 08:06 AM   #9
Oakman's Avatar
My 6.4 diesel take 15 quart of oil w/ filter. It does get expensive when I have both fuel filters changed. Regardless, I could never go back to a gasser.
Bob and Joyce
ATU Local 788
Old 05-01-2014, 08:08 AM   #10
Camper Less Camping
Cajun Po-Boy's Avatar
10 qts. @ 4.00 a qt
TURBS
X2
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
