Old 05-21-2014, 07:24 AM   #11
Herk7769's Avatar
ST tires only for my 5th wheel as well. LT tires are designed from scratch for near continuous use. ST tires are designed for sitting for long periods; then put in high speed high stress use immediately.
Here is what Trailer Life has to say.
File Type: pdf TRAILER LIFE - LT vs ST Magazine Article.pdf (1.91 MB, 53 views)
HAM CALLSIGN - KC3FFW
Old 05-21-2014, 08:33 AM   #12
f5moab's Avatar
This is one of those coke vs. pepsi debates.
The pro-ST side says ST tires because they're designed for the sheering forces of backing and turning the trailer on multi-axle trailers. They're special trailer tires and should be used for such. Their claim is that LT tires aren't designed for trailers and shouldn't be used for it.
The pro-LT side says LT tires are a better made/heavier tire and that ST tires are problematic. They give examples that some higher end/heavier campers use LT tires from the factory.
It's a debate that rages on and on and on...
For what its worth, ST tires for me.
I agree, but will add that many off-road designed popup trailers come with LT tires. From my experience, ST tires do not hold up to sharp rocks; whereas, AT/MT tires designed for off-road use do hold up.
If I was only highway, I would probably go with Goodyear Marathons, but since I do pull my trailer down some serious type roads; I went with non ST Tires.
f5moab is offline   Reply With Quote
Old 05-21-2014, 08:40 AM   #13
Herk7769's Avatar
Valid point. Not all situations are the same.
Great photo BTW.
Old 05-21-2014, 09:09 AM   #14
Fulltime family RVer
I think you have a typo and missed a part here:
If I was only highway, I would probably go with Goodyear Marathons, but since I do pull my trailer down some serious type NON-roads; I went with non ST Tires.
Way cool.
5th wheel, tire, tires, wheel
