Old 02-18-2014, 01:48 PM   #61
B47
Originally Posted by ourflat View Post
We've called them Security Forces
Yeah - I'm going back to the 1960's when I was in SAC. A lot has changed since then.
But there was two separate branches of security in SAC when I was in - the Air Police wore the pretty uniforms with the white hats and pistols,etc. They were stationed at the gates and patrolled the base with the exception of the flight lines and Alert areas. The guys on the flight line wore fatigues ( I told you this was in the 1960's during the Cold War). They carried rifles,guarded the airplanes and controlled entry to the Alert areas. They also worked with the dogs in the Alert areas.
Old 02-18-2014, 02:13 PM   #62
ourflat's Avatar
Elite Guard. I closed my career out as a Group Security Forces First Sergeant, We also used them as private security details for the Generals.
Frank
2016 Days Camping so Far: 24
2013 3051S Forester
2013 Elantra GT (Toad)
WashU EMBA "39
ourflat is offline   Reply With Quote
Old 02-18-2014, 02:21 PM   #63
bubbles's Avatar
I believe there was 2 different areas of responsibility within the Air Police sqdn. Law Enforcement and Security. Maybe not.
Old 02-18-2014, 02:25 PM   #64
ourflat's Avatar
Both missions were contained in one squadron. AF eventually combined both career fields into one and now nothing really works well! Bring back SAC!
Frank
2013 3051S Forester
WashU EMBA "39
Old 02-18-2014, 03:04 PM   #65
Herk7769's Avatar
Lou - did you know at one time there was a C-130 aerial demonstration squadron? I think they were based at Ardmore AFB in Ardmore OK when that base was open.
I have a book about them - let me know if you want additional info about them.
I do as well. I also have the movie (The Four Horsemen) but you can watch it on YouTube here.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 02-18-2014, 03:34 PM   #66
It is an OV-1D Mohawk. I worked on the IR surveillance system in Vietnam.
Old 02-18-2014, 03:54 PM   #67
B47
Could be. All I know is what I saw back then. When I was ever in the Alert area,those guys with the rifles and dogs didn't know too friendly.
And that Air Policeman who pulled me over for being 2-3 miles over the speed limit in the Dyess AFB base housing area was wearing his pretty uniform and had his pistol on.
Old 02-18-2014, 04:00 PM   #68
B47
I guessed the wrong base for these guys. That type flying must have aged these guys fast - kinda old looking for Captains.
Still pretty impressive - I didn't know those C-130's they used for that flying were "stock" ones. I heard that planes used by the Thunderbirds are modified for that type flying,but can be brought back to combat ready configuration if necessary.
Old 02-18-2014, 04:09 PM   #69
PPST OGCDG
Frank-VA's Avatar
Originally Posted by Oakman View Post
Yep, support is very important. Someone was always standing out there 24/7 to make sure no one could steal a B-52.
Attachment 46423
I can Name the Van in Front of the B-52. It is a International Metro Van
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
Old 02-18-2014, 04:15 PM   #70
B47
Yep - and the "C 12" is its call sign for Job Control to call. Ours had a plywood square covered in plexiglass with all our Tail Numbers on it that maintenance was due on or the airplanes status. The board sat on top of the engine cover.
Old 02-18-2014, 04:40 PM   #71
LKicklight's Avatar
Mohawk
Built by grumman aircraft back then, great little re-con plane:
Originally Posted by jevanb View Post
digging thru old photos and i found this. Man was i young, 22 years old. Anybody know what model this is? Probably the vietnam guys might of seen it around.. And the desert storm fellas
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
