Old 05-07-2016, 06:28 PM   #1
Check out Mars & Saturn this month
Mars and Saturn, May 2016 – low in the southeast around 11 PM local time, or just before sunrise low in the southwest, look for a bright triangle, 7 to 10 degrees on each side (your fist subtends roughly ten degrees when you extend your arm). The brightest is Mars (slightly orange-red, not twinkling) followed by Saturn (yellowish, not twinkling) and the star Antares. One month is about 2 hours of sky-time, so this trio will appear that much earlier by the end of the month but the distances between them will change - after all, 'planet' means 'wanderer'. Mars is only this bright when near opposition, which occurs May 22, after which it will slowly dim. If out before 3 AM, don't miss brilliant Jupiter, farther west and a bit farther north. A steadily held binocular may show up to 4 of Jupiter's moons.
Steve & Debbie Russell
2013 Sunseeker 2900
TelescopeClinic
Starry2some is offline   Reply With Quote
Old 05-07-2016, 06:36 PM   #2
asquared's Avatar
Thanks I will have to have my DD look through her telescope.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
