02-06-2019, 04:22 PM
Always Learning
Cutting 2-3" PVC
My wife wants to make a storage container for rolled up sheets of vinyl for her crafting business.
Here's the inspiration:
Any time I've ever cut PVC with a hacksaw, it's super fugly.
Any tips, tricks, tool recommendations for cutting 2" and 3" PVC?
02-06-2019, 04:30 PM
I use a chop saw but I have a workshop. You could try getting the PVC at Home Depot or Lowes and having them cut 10 foot pieces to the right length. They also sell shorter lengths but I am not sure if they have the short lengths in 3 inch diameter.
Hank, Dianna and two fur babies Cody and Bella
2016 F250 PSD CC/SB
2018 Crusader 338RSK
02-06-2019, 04:33 PM
Cut with fine tooth hack saw. When finished, use small pocket knife and run it around inside and outside of the cut tubes. You could also use a PVC cutter if uou want to spend extra money.
02-06-2019, 04:35 PM
Always Learning
Is there anything I need to know/worry about with a chop saw? I have a friend in the area, but don't know if they have one. This RV park has "workshop" on their campground map, but I also don't know what it takes to get into there.
I'd hate to ruin a saw or blade or something.
02-06-2019, 04:36 PM
You can use any mitre saw with any wood-cutting blade. If your blade isn’t big enough for the 3”, just spin it as you cut. I’m a plumber and I’ve been doing it this way for decades.
Bruce
02-06-2019, 04:39 PM
Also, be careful when you are cutting any plastic pipe, but be especially careful when cutting foam core PVC, because it likes to shatter sometimes.
Bruce
They make a pvc saw and also a ratcheting cutter. The pvc saw will leave a rough edge but a little sand paper cleans it up. The ratcheting cutters work good and leave a smooth cut but on pipe that size the blade can wander a little and make a not so straight cut (at least for me, maybe a better quality one would do better). Any big box store or hardware store should have them.
_________________________
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
02-06-2019, 04:56 PM
There are a lot of ways to cut PVC pipe. The first thing to do is to wrap the place you're going to be cutting it with painters tape.
A power saw (miter, table, sawzall, etc. (not chainsaw) ) with a fine tooth blade will make relatively smooth cuts if you don't force it.
Then a little sand paper and some heat will make it smooth as glass. Just be careful with the heat as too much will orange peel it.
Gotta go campin!
02-06-2019, 05:04 PM
RV There Yet?
Miter saw is your best friend. bonus fact: there are several brands that offer a battery powered version (perfect for camping)
I prefer to use a "V" block to keep it from rolling as i cut. and dont stick your fingers inside to hold it, surest way to lop them off! ask me how i know this
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
02-06-2019, 05:12 PM
RV There Yet?
Bruce
please be careful! your shop teacher is cringing while you do this! if you are not comfortable with a saw, do not do this. we dont need to change your name to stumpy. I have hit the E Stop in my shop classes for students who practice unsafe things like this.
i have not met a 10" saw that cannot cut through 3" pipe. i have seen smaller ones have trouble (7.25 to 8.5 inch saws). but from his questions and implied lack of experience, i will not offer solutions/tips/tricks that could cause the loss of fingies.
minimum 10" saw with "V" block or find someone in the park who can assist you
Stay Safe!
2018 17RP
I’ve cut 3 & 4” pvc many times using my chop saw. Works like a charm. You just need to make sure the pipe is secured tightly so it doesn’t spin. Then take a fine toothed file to debur the edges. I put a 6” length of 4” pipe around all of my sprinkler heads to make it easier to remove & clean or replace them.
02-06-2019, 05:45 PM
X? on the miter saw... Go slowish as you cut. The PVC will leave marks on their blade if that matters. Band saw works very well. Sawzall with some patience does well.
Get schedule 5 or 10 as opposed to S40 lots easier to cut
Coming by Arkansas? I will happily cut it on our $5000 band saw. No charge
2017 Puma 297RLSS
Doug you are over thinking this. A chop saw will work fine. PVC is easy to cut and won't hurt the saw. Use common sense precautions. You make need to sand the cuts a bit.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
02-06-2019, 08:15 PM
While on the job site one day saw a long time plumber use a peice of nylon string to cut a pvc sewage line in the bathroom.
Did not believe that he say he used the string so he cut the peice he just cut off and cut it in half again.
02-06-2019, 08:30 PM
Cutting PVC with a Miter or Chop Saw is not a problem, but it does make a mess! The plastic residue is a lot different than sawdust. Full of static and clings to everything it comes in contact with.
2016 Salem 27RKSS
02-06-2019, 08:31 PM
Love her idea but PVC is mighty heavy. Might want to think about using cardboard craft rolls or the like instead?
2009 FreeLander - Retired
2015 FR3 30DS - Retired
2023 Sunseeker 2440DS
Towing 2016 Chevy Sonic LT
02-07-2019, 10:44 AM
True. The weight of that PVC adds up after a while. Cardboard mailing tubes would be my choice. Cheaper generic craft tubes are readily available at Michael's or Hobby Lobby.
2016 Salem 27RKSS
02-07-2019, 11:05 AM
Always Learning
Welp, we bought a 10' x 3" tube and two 10' by 2" tubes. I have to cut them each into 12 pieces.
I think the challenge is the diameter. She wants 2-3" round so can easily get the pieces in and out and maximize the space.
I'm curious if thin-wall PVC would be lighter. I found a plumbing supply place in the area that I might call before I start cutting this PVC up.
02-07-2019, 01:44 PM
DWV (Drain Waste Vent) PVC is a lot lighter than Schedule 40. You do have to be a little more patient cutting it because of the wall thickness.
Gotta go campin!
02-07-2019, 02:46 PM
Google Plastic resellers. We have TAP Plastic on the West Coast. They can cut any length Plastic pipe you want. The UP side is they carry Acrylic Tube which is way lighter than PVC and is clear also.
