Old 10-25-2013, 07:30 PM   #11
Dodge Guy's Avatar
I have never done it, but with a low psi washer and if you now what you are doing I don`t see an issue. you have to know where you can pressure wash and what to stay away from.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 10-25-2013, 07:41 PM   #12
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
I would never pressure wash my 5ver...PERIOD!!!! When I wash by hand I can inspect all the seals at the same time. After I hose down I go inside and check for any leaks.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is online now   Reply With Quote
Old 10-28-2013, 06:32 AM   #13
NELA
Weezer's Avatar
For the record I've seen this same guy pressure wash the seats in vehicles he's detailing.
Yes, he removes them from the vehicles, puts them on racks he built out of 1 inch pipe and pressure washes them. I have no idea how he gets them dried.
I'd considered letting him detail my personal vehicle. I've rethought that. Uhhhh I'll pass.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 10-28-2013, 07:04 AM   #14
Arefbee's Avatar
I'm guessing he started out as a boat detailer.
If done right, a pressure washer would be OK. Just don't get too close to the surface, keep it the pressure on the low scale. I also believe I would not do it right and a few patches would be the result so soft car wash brush here.
I could see it working on car seats as well long as they are just surface washed. The trick is to not let it soak in, same as a carpet shampooer.
2011 PrimeTime Tracer 2600rls
2001 GMC Yukon XL 2500, 6.0L 4.10:1 axle ratio
Nights camping 2014 - 17
2013 - 15
Arefbee is offline   Reply With Quote
