Forest River Forums
Sunline User Photos
Old 06-28-2011, 01:49 PM   #1
Warrior's Avatar
Drinking water
Do you drink the camp grounds water, or do you bring your own drinking water? Or do you use the water from your fresh water holding tank?
Does the water pass through the onboard filter when the camper is connected to the hose bibe at the site or is it only filtered when water is being drawn from the tank?
Warrior is offline   Reply With Quote
Old 06-28-2011, 01:51 PM   #2
Moderator
mtnguy's Avatar
I drink campground water so I am not carrying a bunch of weight.
Both sources should go through the onboard filter.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
mtnguy is offline   Reply With Quote
Old 06-28-2011, 04:16 PM   #3
Moderators' Assistant
bikendan's Avatar
since i have plenty of extra towing capacity, i usually will fill the FW tank.
but i have never had problems refilling with campground water.
never had bad tasting water at any campground we've been to.
but, i used to backpack a lot and used iodine tablets, so i'm not as picky about water taste as most of Americans are.
Old 06-28-2011, 06:22 PM   #4
2Susan's Avatar
First get a good fresh water hose - the complimentary hose from the dealer gave the water an awful plastic chemical flavor. New and more expensive hose - no off taste at all.
We have a filter that is external (buy them at Wal-mart even) before the water enters the rv to keep sediment out.
2011 Georgetown 320DS new June 2010
days camped in 2010: 61
days camped in 2011: 37 (up to Aug 1st)
2Susan is offline   Reply With Quote
Old 06-28-2011, 06:31 PM   #5
Bilcin's Avatar
2Susan,
We just used a $19 external water filter. Can I re-use this? I hate to use the filter for 4 days and throw it out, or can I wrap it in a papertowel and put it in the refridgerator or freezer? Or do have to buy a new one every time?
Bill & Cindy McKenna
Philadelphia PA
2011 Wildwood 26TBSS
2005 Ford F150 5.4 Triton V8 4x4 XLT
Bilcin is offline   Reply With Quote
Old 06-28-2011, 06:54 PM   #6
MrT
MrT's Avatar
We generally consume the campground's potable water. That said--even with the onboard water filter system, we usually purchase bottled/jug water for making coffee if the campground's water has poor taste or excessive chlorine.
2010 Rockwood 8314SS Signature Ultra Lite
2007 Nissan Titan Crew Cab SE 4x4
Reese Dual-Cam | Tekonsha Prodigy P2
Camping Nights: 2009 (8) | 2010 (17) | 2011 (32) 2012 (~35)
RIP: 1997 Jayco 1208, 2000 Jayco Heritage Laurel
MrT is offline   Reply With Quote
Old 06-28-2011, 07:21 PM   #7
2Susan's Avatar
Post re-using filter
it's a good question. We have been using that same external filter trip after trip. When pressure is reduced with the filter in place, it's probably clogged with sediment and should be replaced. But, the filter sits in between trips and logically something could be growing in there. I had not given it much thought really. If it's not empty and you chuck it in the freezer it could crack - but I'm thinking it probably you can get it empty enough. Another option might be to pour some bleach in but rinsing might be an issue. Freezing actually doesn't sound like a bad plan. I wonder how often others replace their external filter!
Old 06-29-2011, 12:06 PM   #8
Moderator
mtnguy's Avatar
Concerning reusing the external filter, I buy an new one at the start of every camping season. After each time i use it, I blow it out, so hopefully nothing will grow in there while it is not being used. Before hooking up my water hose, I will also run the hydrant water through it for a couple of minutes to flush it.
2008 Surveyor 263
Old 07-08-2011, 12:59 PM   #9
I am not too picky, but DW is another story. We leave home with a full tank of water from the house and drink that. When we are doing a lot of fishing and need coolers with ice, we buy bottled water. I freeze it solid at home and use it for ice in a clean cooler. I add frozen bottles to the fish cooler as needed, and DW will grab a clean bottle to drink now and then.
akcampr is offline   Reply With Quote
Old 07-08-2011, 01:03 PM   #10
Bottled water is one of the biggest rip off's known to man. We use camp ground water. The only time I fill my tank full is if we are boon docking. Then it will be refilled from campground sources if available.
» Online Users: 527
85 members and 442 guests
Adony, armcor02, bidesheng, bjlowe, blaisrv, bmcgee, Bruce and Lynn, buccello, bumper, caleb, Capsfloyd, COcamper, Coops1, dashonthedash, Dave_Monica, daw592, DDC, ddemme, DonG, dunnnc, firemanrod, flc, Frank4, Ggantilla, gimp425, grhodes50, Hilgy, hjmiberry, House97, Hydrothunder, Iggy, imabmwnut, itech, J McClure, JamesR, JDWeir, jjhwisconsin, JoeR, jonnys_walkers, J_King, Kirby, klucas, majag86, mbrwr, meatguy, mlhalter, Murray10, mwilson949, myredracer, N3HCP, newtsx3, NO3putt, OffPavement, papamcgown, partime, pg_rider, Phil57, punkaccountant, redfox217, ret2006, rgfenner, RiverratII, rkswyo, RRkevin, rwhmtnfolks, sandys, sbond, Scooter2, sfrye5853, Skeet, Smithee, snackage, Sparky44, sprayking, SpringerPop, sundawg, Taranwanderer, Terier, troyt, tsmcmillen, vasnipe, VinceU, wagon52, Whiteknight, wingriders
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
