Old 09-13-2015, 05:06 PM   #1
Left Coast
Figure this out
Have small pond out front......installed new pump (little one from Lowes). With pump running, you put your finger in water...pump stops. Dog takes drink...pump stops. Cat takes drink...pump just slows down. Electrical outlet is a new duplex wired correctly.......plugged a drop light in to the other side of plug...light stays on and no flicker....have run a leaf blower thru 50' cord...no problem....Whats going on?
Old 09-13-2015, 05:40 PM   #2
Phat Phrog Stunt Crew
elind's Avatar
Bob, I think you have a problem.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 09-13-2015, 05:56 PM   #3
DDC
DDC's Avatar
The pump could have a problem, have you tried it on another outlet you can use that 50' extension.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 09-13-2015, 06:53 PM   #4
Paradise has arrived!
Paradise115's Avatar
Or.....you have really smart fish in your pond..
Southwestern Pennsylvania
Paradise115 is offline   Reply With Quote
Old 09-13-2015, 07:10 PM   #5
Left Coast
All of the above......I did plug it into an outlet in the kitchen, it's got a long enough cord,same thing
Old 09-13-2015, 07:15 PM   #6
Iwannacamp's Avatar
??? Double insulated ???? Internal GFCI protected? Goblins??
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Iwannacamp is online now   Reply With Quote
Old 09-13-2015, 07:25 PM   #7
Ford Idaho's Avatar
Is the water pumped thru metal or plastic pipe?
Have you ran a continuity test on the pump leads?
Is the pump grounded any place else but the ground lead to the outlet?
Amps at the pump VS at the outlet?
Old 09-13-2015, 07:28 PM   #8
Left Coast
No GFCI......Outlet is in alcove.......double insulated......also, there's 2 freezers on that circuit. No pipe/conduit.......
Old 09-13-2015, 07:32 PM   #9
Left Coast
No other ground...meter on leads...wiggled cord...kept continuity. Pulls 0.12 amp.
Old 09-13-2015, 07:41 PM   #10
Flybob's Avatar
You sure you do not have a GFI upstream? Most relatively new homes have GFI protected outlets ofr outside.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
