Old 02-02-2013, 02:04 PM   #11
TURBS's Avatar
Old 02-02-2013, 02:10 PM   #12
Engineer of Crazy Train
ChooChooMan74's Avatar
Hey Turbs, what was the temp when your fuel gelled up? It has gotten down to 5 here and no issues with my Jeep. Does the Duramax have a fuel heater in the bowl? The original filter for my Jeep had a "puck" that had a heater where the filter screws on, and my aftermarket replacement has an element in the fuel bowl.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 02-02-2013, 02:15 PM   #13
TURBS's Avatar
choochoo,
It was about -15 I had truck plugged in with a timer that came on at 2 am.
the filter has NO heater on it ......
My filter dic monitor was at 30% wednesday.
and went to 0% yesterday morning then the reduced power/check engine light came on.
As I said I doubled my antigel additive but I have my suspisions that the filter needed changed anyway.
I am going to start changing it "depending on milage" or "weather" at about 30%
Old 02-02-2013, 02:26 PM   #14
-15 is sure cold. You can keep it out there!! Summer will be here before you know it.
I wouldn't want the job of changing your filter. Looks like GM had a brilliant idea when they designed that. Although, your mod does make it a lot easier to get to.
Locomotive Engineer
Old 02-02-2013, 02:29 PM   #15
TURBS's Avatar
Yeah considering you have to pull the inner liner out otherwise to replace filter.
Old 02-02-2013, 03:22 PM   #16
Camper Less Camping
Cajun Po-Boy's Avatar
Why so many Dmax guys go with the FASS or AIR DOG fuel setups and install under front doors inside truck frame...way easier to access than the stock location (besides the better filtration aspects & fuel delivery when your running higher HP #'s)...GM has the TD engine crammed under these hoods!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 02-02-2013, 03:31 PM   #17
10x
This is why I left Illinois 22 yrs ago.
10x is offline   Reply With Quote
Old 02-02-2013, 06:25 PM   #18
bob213's Avatar
Thanks Turbs..added to my mod list.
bob213 is offline   Reply With Quote
Old 02-02-2013, 06:26 PM   #19
TURBS's Avatar
Your welcome!
Anything to make your day just a little better!
Old 02-02-2013, 06:36 PM   #20
Oklahoma Proud
MillerTime's Avatar
Ill have to start saving damaged wheel liners for you guys to make access hole covers.
- I usually change my filter at about 5k- which is about once every 9-10 months.
