Old 02-01-2013, 11:04 AM   #1
TURBS's Avatar
first gel up this year.
Filled my truck up Wednesday and added double the antigel knowing it was going to be cold today.
5 minutes from home on the way to work this am the change fuel filter light came on. "Service minder was at 30 percent Wednesday" and immediately after the check engine light came on with the message "reduced engine power"
50 mph to work .
Pulled into shop and changed filter
Reset engine light
Installed a bottle of 911
All Is good!
By the way filter change on the lmm was
> 10 minutes with my "access hole" cover I built off of the design of one pictured below.
Turbs
Old 02-01-2013, 11:05 AM   #2
TURBS's Avatar
Old 02-01-2013, 11:38 AM   #3
bob213's Avatar
What did you use for material to make your access cover? I'm too short to work from the top and can't seem to get the filter thru anyway. I always have to remove fender skirt. I like your access door better. Saw a high dollar premade setup but would rather try it myself. yours looks like a good way to go. Thanks, Bob
bob213 is offline   Reply With Quote
Old 02-01-2013, 12:29 PM   #4
TURBS's Avatar
Bob I went to the local trucking parts place and bought a plastic mudflap for a big rigger then cut out a piece bigger than my hole.
I used a heat gun to warm plastic and form it to inner fender skirt.
Then drills some holes and used 1/4 "
U nuts to hold it in place.
I also used foam around the edges to seal it.
I'll post up a pic.
Turbs
Old 02-01-2013, 12:30 PM   #5
Herk7769's Avatar
Turbs,
We have the same truck.
I would also like to know what you did and how you made that cover.
Seems like a "truck mod" is in my future.
Herk
HAM CALLSIGN - KC3FFW
Old 02-01-2013, 12:31 PM   #6
TURBS's Avatar
I'll take it off tonight and show the size of hole.
Werks great!
Turbs
Old 02-01-2013, 02:57 PM   #7
Camper Less Camping
Cajun Po-Boy's Avatar
Werks great!
Turbs
Nice...
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 02-01-2013, 03:02 PM   #8
TURBS's Avatar
Originally Posted by herk7769 View Post
Turbs,
Herk
I'll take measurements!
Old 02-02-2013, 01:49 PM   #9
TURBS's Avatar
Ok the hole I cut
Is 7" wide
The panel I made was 9" wide x 10" long.
I cut my hole Just about centered in the fender liner and I could have moved the center towards the rear more but that left me with very little flat surface to be able to seal with the filler panel.
Turbs
Old 02-02-2013, 02:01 PM   #10
TURBS's Avatar
