Old 01-20-2013, 10:49 PM   #11
I plug my truck in whenever it gets below 0 C. (32 F.). I only have the winterfront on the grille even though I have the bumper cover also. Truck has NOT thrown a code in the time I've owned it and plugged it in. Tonight it is supposed to get down to -32 C (-25.6 F.). I have a heated garage so not plugged in tonight but at work it is always plugged in below freezing.
Ken & Janet
'07.5 GMC 2500 D/A CC/SB
'09 SABRE 31RETS-6
wingriders is online now   Reply With Quote
Old 01-21-2013, 06:57 AM   #12
I had a 2001 that would throw a code. It was the fuel temperature sensor, if I can remember correctly. If it sensed a 10 degree difference from the tank to the sensor then it would throw a code. That would only happen when it was plugged in with the front cover on.They changed it out under warranty but it kept happening. I would have them check it with a Tech2 and if that was the code then I would have them clear it. I eventually got a tuner for it and I cleared the code myself. I now have a 2011 and have been plugged in and have the front on and no problems ....so far.
Pipeman is offline   Reply With Quote
Old 01-21-2013, 08:11 AM   #13
AquaMan's Avatar
I plug in when I get home in evening, if it's anywhere around freezing, and it stays there until morning when I hit the remote start while finishing my coffee.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 01-21-2013, 08:46 AM   #14
H2oski
Okay I had to go there. We don't have to worry about plugging in down here, 70 degrees today. HAHAHA.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 01-21-2013, 09:23 AM   #15
TURBS's Avatar
Yours Prolly didn't even come with a block heater!
Turbs
Old 01-21-2013, 09:24 AM   #16
TURBS's Avatar
You leave yours plugged in while running?
Turbs
Old 01-21-2013, 10:10 AM   #17
AquaMan's Avatar
I do leave it plugged while running, at least until I walk out to leave. I always put the defroster on before I shut it off in the evening also, which helps keep the window clear. Although when I start with the remote start, it automatically turns defroster on with fan high regardless of setting.
Old 01-21-2013, 11:37 AM   #18
Helmsey's Avatar
I will generally plug mine in below freezing, plug it in before I go to bed the night before and unplug when I leave in the morning for work. It might be just a mental thing but I think i get warm air in the cab faster when I plug it it.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 01-21-2013, 11:48 AM   #19
TURBS's Avatar
I sure had a shorter warm up time this am with it plugged in!
It came off of fast idle quicker!
Turbs
Old 01-21-2013, 12:55 PM   #20
Oklahoma Proud
MillerTime's Avatar
I have plugged in when ever it is 32f or below. Never had a code, usually plugged in the night before. And I believe most are coolant heaters- thread into the water jacket on the block. Of topic, but my buddy with a 6.0 ford plugs in when it is in the 50s. I think its time for a fuel module and program update though.
