01-20-2013, 09:33 PM
for those of you with a d-max
Since I am new to the d-max but not diesels in general....
At what temp do you guys start to plug them in for a cold winter morning start?
Iv e yet to even put on the winter front on but tomorrow morning is supposed to be the coldest morning of the season for us .... I know I know a balmy -3* degrees F. with a high of 8*
At work we have timers on our big trucks which kick on about 3 am .
just wondering what you guys do .
TURBS
01-20-2013, 10:06 PM
The manual says to use it below 0. Our forecast for tonight is a low of 1. I plugged mine in.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
01-20-2013, 10:11 PM
Actually I believe I read that and totally forgot ...... stupid turbs !
I think I read that the winter front needs to be on in continuous below 0 temps as well.
I guess I just like your guys advice better !
Do you have yours on a timer ?
I had a 15 amp timer laying around that was used for a dairy operation and had the timer come on at 2 am for a 515 am start.
thoughts ?
TURBS
01-20-2013, 10:32 PM
I plugged mine in 1time and the temp was around 30 , it thru a code and would not accell at all (like a limp) cleared it and all good . do not plug in above 0 degrees.
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
01-20-2013, 10:33 PM
what was the code number ?
TURBS
01-20-2013, 10:34 PM
cannot remember I never plug it in but the truck lives in the garage, not heated...
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
01-20-2013, 10:37 PM
i could easily pull it in the garage as well but toby lives in there during the winter and he probably doesn't like the fumes when i start it !
01-20-2013, 10:43 PM
I also do not put on the winter cover because my egt' s are 200 degrees higher with the intercooler covered, I think they were higher than that with the stock exhaust including that piece of crap downpipe and cat
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
01-20-2013, 10:46 PM
Is your cover the one that covers grill and bumper ?
I heard they went away from that as when I bought mine it was just the grill !
TURBS
01-20-2013, 10:50 PM
it is a 2piece one for the grill and another for the the bumper which I cannot figure out.lol
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
01-20-2013, 11:49 PM
I plug my truck in whenever it gets below 0 C. (32 F.). I only have the winterfront on the grille even though I have the bumper cover also. Truck has NOT thrown a code in the time I've owned it and plugged it in. Tonight it is supposed to get down to -32 C (-25.6 F.). I have a heated garage so not plugged in tonight but at work it is always plugged in below freezing.
Ken & Janet
'07.5 GMC 2500 D/A CC/SB
'09 SABRE 31RETS-6
01-21-2013, 07:57 AM
I had a 2001 that would throw a code. It was the fuel temperature sensor, if I can remember correctly. If it sensed a 10 degree difference from the tank to the sensor then it would throw a code. That would only happen when it was plugged in with the front cover on.They changed it out under warranty but it kept happening. I would have them check it with a Tech2 and if that was the code then I would have them clear it. I eventually got a tuner for it and I cleared the code myself. I now have a 2011 and have been plugged in and have the front on and no problems ....so far.
01-21-2013, 09:11 AM
I plug in when I get home in evening, if it's anywhere around freezing, and it stays there until morning when I hit the remote start while finishing my coffee.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
01-21-2013, 09:46 AM
H2oski
Okay I had to go there. We don't have to worry about plugging in down here, 70 degrees today. HAHAHA.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
01-21-2013, 10:23 AM
Yours Prolly didn't even come with a block heater!
Turbs
01-21-2013, 10:24 AM
You leave yours plugged in while running?
Turbs
01-21-2013, 11:10 AM
I do leave it plugged while running, at least until I walk out to leave. I always put the defroster on before I shut it off in the evening also, which helps keep the window clear. Although when I start with the remote start, it automatically turns defroster on with fan high regardless of setting.
01-21-2013, 12:37 PM
I will generally plug mine in below freezing, plug it in before I go to bed the night before and unplug when I leave in the morning for work. It might be just a mental thing but I think i get warm air in the cab faster when I plug it it.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
01-21-2013, 12:48 PM
I sure had a shorter warm up time this am with it plugged in!
It came off of fast idle quicker!
Turbs
01-21-2013, 01:55 PM
Oklahoma Proud
I have plugged in when ever it is 32°f or below. Never had a code, usually plugged in the night before. And I believe most are coolant heaters- thread into the water jacket on the block. Of topic, but my buddy with a 6.0 ford plugs in when it is in the 50°s. I think its time for a fuel module and program update though.
