Old 07-22-2016, 10:29 AM   #41
Originally Posted by RSchleder View Post
Even with the car running, the battery supplies the 12V to the accessories and engine so the alternator simply recharges the battery as it's power is depleted.
Not true. The alternator is putting out a higher voltage and the battery is just another LOAD (that why it's being charged) for the alternator to supply.
(You could quibble about the battery "filtering" any ripple in the alternators output, but overall, the battery is still a LOAD.)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 07-22-2016, 10:40 AM   #42
Originally Posted by Blackhat6mike View Post
29 out of 30 and I still argue that the radio runs off the battery and not the alternator. Take the alternator out and the radio will still work. Remove the battery and everything stops. JMHO
Agree with everything you say except once the engine is started, you can remove the battery and the engine will still run off the alternator/generator.
Old 07-22-2016, 10:50 AM   #43
RSchleder's Avatar
I stand corrected. Thank you Gentlemen!
Days camping (2016)----181 days
Days camping (2017) --- 52 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 07-22-2016, 05:48 PM   #44
WolfWhistle's Avatar
since the alternator is putting out higher voltage than the battery, the alternator is the power source. without an alternator the battery is source.
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
A Modder's work is never done!
Old 07-22-2016, 06:30 PM   #45
win
win's Avatar
X2
win is offline   Reply With Quote
Old 07-22-2016, 09:30 PM   #46
indybp57's Avatar
28/30. Otto who??!! I missed the other one when my wife flopped on the bed just as i was answering and caused me to hit the wrong button. I swear
Sent from my 9020A using Tapatalk
2013 Roo 183
2012: 1042 Miles, 13 Nights camped
2013: 2772 Miles, 27 Nights camped
2014: 2259 Miles, 30 Nights camped
2015: 1644 Miles, 20 Nights camped
2016: 550 Miles, 11 Nights camped
indybp57 is offline   Reply With Quote
Old 07-25-2016, 06:24 PM   #47
Name:	ImageUploadedByForest River Forums1469489069.782922.jpg
2015 Trilogy 38RE
-lenny- is offline   Reply With Quote
Old 07-25-2016, 06:49 PM   #48
30 out of 30, he says as he shines his knuckles on his chest. But I cheated on one (Thanks Google) and got a hint on another.
More bragging: I came in 3rd in the state of Minnesota in the Future Farmers of America mechanics contest. Back then we were just moving on from steam engines. (well, not quite that long ago, mid 70's)
2014 Ford F150 EGOBoost
2016 Rockwood 2502ks
jlmanatee is offline   Reply With Quote
Old 07-25-2016, 08:16 PM   #49
DDC
DDC's Avatar
A vehicle with a generator will continue to run if you disconnect the battery, however the same with an alternator will not unless it supplied with 'exciting' power, an alternator needs power to produce power.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 07-25-2016, 10:10 PM   #50
VinceU's Avatar
In reality they both require excitation voltage which regulates the voltage level. When either unit is "self excited" it will run on without a external power supply once up to speed. The difference between a generator and alternator is the generator excitor is stationery poles on the exterior of the case. With the armature rotates a commutator converts the voltage to DC.
In the alternator the field poles rotate with the controlled voltage/excitation to maintain a AC output from the Stator 13-14 volts are output, then converted to DC power.
So they both require excitation power and designed properly can self excite.
