Old 07-28-2016, 01:00 PM   #51
Rugged Brown's Avatar
Originally Posted by OldCoot View Post
Agree with everything you say except once the engine is started, you can remove the battery and the engine will still run off the alternator/generator.
How did you do Old Coot?
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 07-28-2016, 01:18 PM   #52
TURBS's Avatar
27
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "22"
TURBS is online now   Reply With Quote
Old 07-28-2016, 01:32 PM   #53
27 out of 30
Soxfan1957 is offline   Reply With Quote
Old 07-28-2016, 01:57 PM   #54
29 out of 30,I took a "Dive" so You cant call me a "Know It All"! Youroo!!
youroo is online now   Reply With Quote
Old 08-10-2016, 04:28 PM   #55
28 for me as well.
Gibbsey is offline   Reply With Quote
Old 08-10-2016, 05:10 PM   #56
mlangdn's Avatar
27\30 Not too bad for a shade tree mechanic!
2014 Coachmen Catalina
243RBS 50th Anniversary
2013 F250 Lariat 6.7 Powerstroke
mlangdn is online now   Reply With Quote
Old 08-10-2016, 05:56 PM   #57
28 for me. Amazing how many of the answers I knew from several years of small engine projects in 4-H. Kind of a neat walk down memory lane.
Brian, Stacy, and the girls (8 and 5)
2011 F-250 CCSB 6.7L PSD 4WD
2013 Solaire 269BHDSK
ProPride Hitch
purduepete97 is online now   Reply With Quote
Old 08-10-2016, 07:28 PM   #58
Wobbles's Avatar
A vehicle is DC correct? If that is true, then which way does the juice flow from the battery? From the positive post?
Here is a hint, Why do you you disconnect the negative post when servicing?
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2015 Grey Wolf 26BH
Wobbles is offline   Reply With Quote
Old 08-11-2016, 12:10 PM   #59
2007 WildCat 32QBBS
05CrewDually's Avatar
The current flows from the negative side. This is why older Brit cars were positive earth.
The reason you should ALWAYS disconnect the negative terminal FIRST, is so if you slip with the wrench and touch the vehicles sheet metal or chassis you don't short out and cause a shower of sparks and damage to your wrench!
05CrewDually is offline   Reply With Quote
Old 08-11-2016, 12:20 PM   #60
X2!
Disconnecting negative first has nothing to do with the direction of flow of the current. If you were on an old Brit car, you'd want to disconnect the positive first.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
