07-22-2016, 10:29 AM
#41
Originally Posted by RSchleder
Even with the car running, the battery supplies the 12V to the accessories and engine so the alternator simply recharges the battery as it's power is depleted.
Not true. The alternator is putting out a higher voltage and the battery is just another LOAD (that why it's being charged) for the alternator to supply.
(You could quibble about the battery "filtering" any ripple in the alternators output, but overall, the battery is still a LOAD.)
2011 Traverse LT, 3.6L, FWD
07-22-2016, 10:40 AM
#42
Originally Posted by Blackhat6mike
29 out of 30 and I still argue that the radio runs off the battery and not the alternator. Take the alternator out and the radio will still work. Remove the battery and everything stops. JMHO
Agree with everything you say except once the engine is started, you can remove the battery and the engine will still run off the alternator/generator.
07-22-2016, 10:50 AM
#43
I stand corrected. Thank you Gentlemen!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
07-22-2016, 05:48 PM
#44
since the alternator is putting out higher voltage than the battery, the alternator is the power source. without an alternator the battery is source.
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
07-22-2016, 06:30 PM
#45
X2
07-22-2016, 09:30 PM
#46
28/30. Otto who??!! I missed the other one when my wife flopped on the bed just as i was answering and caused me to hit the wrong button. I swear [emoji57]
Sent from my 9020A using Tapatalk
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
07-25-2016, 06:24 PM
#47
Trilogy 38RE
07-25-2016, 06:49 PM
#48
30 out of 30, he says as he shines his knuckles on his chest. But I cheated on one (Thanks Google) and got a hint on another.
More bragging: I came in 3rd in the state of Minnesota in the Future Farmers of America mechanics contest. Back then we were just moving on from steam engines. (well, not quite that long ago, mid 70's)
2014 Ford F150 EGOBoost
2016 Rockwood 2502ks
07-25-2016, 08:16 PM
#49
A vehicle with a generator will continue to run if you disconnect the battery, however the same with an alternator will not unless it supplied with 'exciting' power, an alternator needs power to produce power.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
07-25-2016, 10:10 PM
#50
In reality they both require excitation voltage which regulates the voltage level. When either unit is "self excited" it will run on without a external power supply once up to speed. The difference between a generator and alternator is the generator excitor is stationery poles on the exterior of the case. With the armature rotates a commutator converts the voltage to DC.
In the alternator the field poles rotate with the controlled voltage/excitation to maintain a AC output from the Stator 13-14 volts are output, then converted to DC power.
So they both require excitation power and designed properly can self excite.
07-28-2016, 01:00 PM
#51
How did you do Old Coot?
Terry/Bernadette Lily the Yorkie 2019 Dodge Ram Sport 1500 2019 FR Vibe 28RL
07-28-2016, 01:18 PM
#52
27
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "22"
07-28-2016, 01:32 PM
#53
27 out of 30
07-28-2016, 01:57 PM
#54
29 out of 30,I took a "Dive" so You cant call me a "Know It All"! Youroo!!
08-10-2016, 04:28 PM
#55
28 for me as well.
08-10-2016, 05:10 PM
#56
27\30 Not too bad for a shade tree mechanic!
2014 Coachmen Catalina
243RBS 50th Anniversary
2013 F250 Lariat 6.7 Powerstroke
08-10-2016, 05:56 PM
#57
28 for me. Amazing how many of the answers I knew from several years of small engine projects in 4-H. Kind of a neat walk down memory lane.
Brian, Stacy, and the kids
2011 F-250 CCSB 6.7L PSD 4WD
2013 Palomino Solaire 269BHDSK
ProPride Hitch
08-10-2016, 07:28 PM
#58
A vehicle is DC correct? If that is true, then which way does the juice flow from the battery? From the positive post?
Here is a hint, Why do you you disconnect the negative post when servicing?
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
08-11-2016, 12:10 PM
#59
2007 WildCat 32QBBS
The current flows from the negative side. This is why older Brit cars were positive earth.
The reason you should ALWAYS disconnect the negative terminal FIRST, is so if you slip with the wrench and touch the vehicles sheet metal or chassis you don't short out and cause a shower of sparks and damage to your wrench!
08-11-2016, 12:20 PM
#60
X2!
Disconnecting negative first has nothing to do with the direction of flow of the current. If you were on an old Brit car, you'd want to disconnect the positive first.
