Old 05-26-2014, 06:33 PM   #21
Ford Idaho's Avatar
DPF is under the truck.
https://www.google.com/search?q=dura...w=1366&bih=712
Old 05-26-2014, 06:33 PM   #22
hrlyguy2's Avatar
2007.5 is when the started the new body style.Lmm is name for your motor.
Lb7.lly.lbz lmm.lml are all gm.diesel engines
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 05-26-2014, 06:34 PM   #23
hrlyguy2's Avatar
No separate section.
Old 05-26-2014, 06:40 PM   #24
Without checking any codes DPF sounds like a high probability. I will have to take it in to the shop tomorrow and get it looked at. thanks for everyones help.
OKI Marine is offline   Reply With Quote
Old 05-26-2014, 06:40 PM   #25
Herk7769's Avatar
I believe it is back by the tail cone.
There should be a diesel fuel line going to it.
2010 Duramax LMM Turbo Diesel DPF Diesel Particulate Filter Exhaust GM | eBay
I know that was for the 2010, but it looks kinda like that.
http://www.ehow.com/how_8561954_clea...l-duramax.html
HAM CALLSIGN - KC3FFW
Old 05-26-2014, 07:05 PM   #26
If it is an 08 it absolutley has a DPF and if there was an issue with the DPF the dashboard display would state "Clean exhaust filter" if it were a clogged DPF due to non completion of regen cycles. I would change the fuel filter as suggested and then if that does not work get the code checked. As stated earlier your shooting blind otherwise.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 05-26-2014, 07:08 PM   #27
jevanb's Avatar
could be a multitude of issues, take the truck to a auto parts store and pull the code, or codes. could be the DPF,low rail pressure , MAF, trans,.ect...the list can go on and on that all cause reduced power. But with out the code everyone is just speculating..
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 05-26-2014, 08:19 PM   #28
Experienced Newbie
I'm comparing apples to oranges here, but my gas 2011 Silverado had a similar issue. Was the throttle position sensor.
Sent from my SM-G900T using Forest River Forums mobile app
2011 Silverado CC/SB
2014 Cougar 31SQB
mhartzel is offline   Reply With Quote
Old 05-26-2014, 09:22 PM   #29
Herk7769's Avatar
Just sayin'
Mine is an 08 Duramax.
Had the exact same error.
Codes showed clogged EGR valve and intake air restriction confirmed by diagnostic run by OnStar.
Solution by GMC dealer was to drop the camper in his yard; drive it back onto the highway to the next exit and back.
By the time I got back it was running great; hooked back up and continued to Florida for 2 months of trouble free driving. Total cost out of pocket - zero.
Old 05-26-2014, 10:06 PM   #30
Herk that sure sounds to me like a remedy for a DPF issue and not the EGR. When the DPF does not complete a regen cycle to clean itself of accumulated soot the prescription is to drive it on the highway. Regen is put on hold under 35 mph in these trucks hence the highway driving needed. After a few failed attempts the "Clean exhaust filter" message can appear.
2013 Wildcat 323QB
(2013 = 36)
(2012 = 42)
power
