Old 03-17-2015, 06:43 PM   #1
Help I-64 Hampton Roads Bridge Tunnel
Will be traveling down I-64 from Williamsport MD to Virginia Beach VA. Problem is that my camper is to tall to fit in the tunnels. (13' 6" max height in tunnels). Best route I see is to cross over the James River Bridge on 17/258 and then cross over another bridge on 17. Anyone have any comments or best route options
OKI Marine is offline   Reply With Quote
Old 03-17-2015, 07:01 PM   #2
Oaklevel's Avatar
How tall is your trailer??? Tractor trailers use the tunnels
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 03-17-2015, 07:04 PM   #3
I'm at 13' 8"
Old 03-17-2015, 07:07 PM   #4
Witch Doctor's Avatar
You are correct on your route IMOP. Tunnels are 13.6'
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 03-17-2015, 07:15 PM   #5
Indymule's Avatar
Don't forget about the downtown tunnel on 264. You gotta go all the way around south.
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
2017 Ford F350 Crewcab Dually Diesel
Ham Callsign K9NDY
Indymule is offline   Reply With Quote
Old 03-17-2015, 07:15 PM   #6
geezer with gadgets
757Dave's Avatar
Hello from SE Virginia.
You have a couple of options you can use. First, you can do as you stated using the James River Bridge and avoid all of the tunnels, but that takes you through a great deal of city traffic and depending on the time of day you could end up in some real traffic problems.
Second, and this is what I do whenever we are returning home traveling south on I-95, while driving south on I-295 (bypass around Richmond) instead of getting off at I-64 east toward Williamsburg continue south on I-295 toward Petersburg and take US Route 460 east toward Suffolk. Continue on this route until you intersect with route 58 east. Stay with that and you will begin to see signs for VA Beach using I-264 east. DO NOT USE This to get to VA Beach. It will take you through downtown Portsmouth and Norfolk via the downtown tunnel. Follow the signs toward Chesapeake using I-64 until you intersect with I-264 after passing the Indian River Rd exits and then follow the signs toward VA Beach using I-264 east. I know that this seems confusing, but you avoid all of the tunnels and downtown traffic, etc. Hope this helps.
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 48
757Dave is offline   Reply With Quote
Old 03-17-2015, 07:18 PM   #7
Oaklevel's Avatar
From VDOTs Web Site if you are over 13'6"
DIRECTIONS TO GET AROUND THE Hampton Roads Bridge Tunnel:
Updated Virginia Overheight Truck Law
DO NOT USE:
The Hampton Roads
Bridge-Tunnel (I-64 WEST)
Downtown Tunnel
(1-264)
Midtown Tunnel
(Route 58)
FROM NORFOLK AND THE SOUTHSIDE: Take I-64 east to 664 north through the Monitor Merrimac Memorial
Bridge Tunnel (MMMBT) back to I-64 west.
FROM WILLIAMSBURG AND THE PENINSULA: Take I-64 east to exit 264 (for I-664 south). Take I-664
south through the MMMBT to I-64 west.
Good Luck !!!!
1966 Mustang GT
1986 Mustang SVO
Old 03-17-2015, 07:42 PM   #8
Gonetothedogs's Avatar
Thumbs up Take I-664 MMMBT
Some info on the Monitor Merrimac Memorial Bridge-Tunnel;
Monitor Merrimac Memorial Bridge-Tunnel, Interstate 664
The I-664 Monitor-Merrimac Memorial Bridge-Tunnel (MMMBT) opened in 1992.
These four-lane twin tubes connect Newport News and Hampton to Suffolk and Chesapeake.
The MMMBT typically carries about half of the volume each day of the Hampton Roads Bridge-Tunnel and is a practical, less-congested alternative.
To travel from Interstate 64 to South Hampton Roads using the MMMBT, take the I-664 South exit (264) and continue to the Interstate 64/264 interchange. The tunnel does not charge a toll.
Restrictions
Maximum height: 14 feet 6 inches (with permit)
Maximum width (with permit): 10 feet 6 inches
Wider vehicles must be escorted by VDOT.
You will have to stop prior to going through the tunnel to prove to VDOT "gatekeeper" that your propane tanks are shutoff. If you don't stop they will chase after you and may give you a fine.
Best of luck
Mac & Joyce
___________________
2012 Ford F-350 Lariat DRW
2015 Sanibel 3901
OK-3 Wire...Living the dream
Gonetothedogs is offline   Reply With Quote
Old 03-18-2015, 11:04 AM   #9
Do they allow propane in the tunnels? I don't think that the one in Baltimore does. Good Luck
whj77372 is offline   Reply With Quote
Old 03-18-2015, 11:23 AM   #10
Oaklevel's Avatar
Virginia does allow propane on RVs, but you usually have to stop to be inspected & they are required to be off.
1966 Mustang GT
1986 Mustang SVO
