05-21-2011, 09:13 AM
Insect Control
I have 2 pugs. I was wondering without harming them, what kind of repellent do you use for ants? Also I was wondering, how do you keep beetles and such from entering the TT where the openings are near the slides? TY for your help.
What do you do to keep Ants out of your TT?
05-22-2011, 03:25 PM
Lou Amadio
If they are bad (and fire ants are the worst) I put ant powder on the landing gear and stabilizer pads and spray the tires near the ground.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
05-22-2011, 03:38 PM
We frequently encounter 'sugar ants' in our travels. We purchase baby powder at a local Dollar store and spread it around any point that the MH touches the ground. We have never had them get across this barrier.
05-22-2011, 03:44 PM
Boric Acid Powder
Boric Acid Powder is relatively harmless (the pharmaceutical grade is used to make eyewash). It stays active pretty much forever - so long as it stays dry. It is not a poison but works mechanically.
Ants (and roaches) have a waxy coating. The bugs walk through the boric acid powder and take it back to their nest. In cleaning the powder off one another they also remove the waxy coating. The waxy coating keeps their moisture in, without it they dry up and die!
The powder is available in a plastic squirt container that looks a lot like a catsup or mustard bottle at a hot dog stand. It's filled with powder and a squeeze makes the powder whoosh out. Squirt it in wall spaces, under drawers, under appliances, behind furniture etc. Find it in Home Depot / Lowes /hardware stores - inexpensive.
If you have fire ants / carpenter ants (destructive dangerous) I'd also add the poison insecticide spray on the outside - reapply after rain. Good luck!
***** ***** ***** 2011 Georgetown 320DS new June 2010
days camped in 2010: 61
days camped in 2011: 37 (up to Aug 1st)
05-22-2011, 03:45 PM
I watched a short article on the Discovery channel where they drew a circle with chalk on a table and then dumped about twenty ants into the center. They were unable to get out. Apparently, any cleanser or talc-like product will stop them. We use baby powder from a local Dollar store and it works great. Simply spread it around any part of the TT or MH that touches the ground. It has never caused us any problem with our very curious old cat, so my thinking is it should be OK for your pugs.
05-22-2011, 04:10 PM
Poison spray
I suppose this spray would be bad for our animals though. Would the boric acid hurt our dogs
05-22-2011, 04:29 PM
Home Defense by Ortho. 10.99 a gallon that last a year or more depending on use. Will not hurt pets and it can be used around the perimeter and inside for all insects. We spray around the tires, jacks power cords touching the ground. We never have ants or spiders. Great around the house too, spray it under cabinets, behind the fridg and stove, near the washer and dryer. None staining and leaves no residue. It really works well.
2011 Cedar Creek 36B2 ordered with outside kitchen removed and a nice big wardrobe in it's place.
Pulled with a 2011 F-250 Super Duty 6.7 Diesel Crew Cab and 8' box with a Hensley Trailer Saver. F R O G members.
05-23-2011, 08:25 PM
Boric Acid is a Powder not a spray -
I would use the Baby Powder Idea and see if it works since it is harmeless to your dog's
My parents used to use Boric acid at the back door to keep roaches out and we had a Golden retriever and it never hurt her but big size diffrence from a pug though.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (7)
USMC 91 - 95 - F/A-18 Aviation Ordnance
05-23-2011, 08:31 PM
boric acid powder
Yes the boric acid is a powder. It comes in a squirt bottle (which to me looks like a larger sized hotdog stand ketchup container). You whoosh the powder out of the spout by squeezing the plastic bottle. It helps to shake it up between whooshes.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 528 |
| 90 members and 438 guests |
| 4kmprs, acadianbob, Adony, armcor02, Barnman1, bidesheng, bjlowe, blaisrv, Bruce and Lynn, buccello, bumper, caleb, Capsfloyd, COcamper, Coops1, Cowracer, dashonthedash, Dave_Monica, DDC, ddemme, DonG, dunnnc, Elidh, firemanrod, flc, Frank4, Ggantilla, gimp425, grhodes50, Hilgy, hjmiberry, House97, Hydrothunder, Iggy, imabmwnut, itech, J McClure, JamesR, JDWeir, JoeR, jonnys_walkers, J_King, kb4srn, ke5wdq, Kirby, klucas, LeonFournier, majag86, mbrwr, meatguy, mlhalter, MN128S, myredracer, N3HCP, newtsx3, NO3putt, OffPavement, papadawg78, papamcgown, partime, pg_rider, Phil57, punkaccountant, redfox217, rerger, ret2006, rkswyo, robert elling, RRkevin, rwhmtnfolks, sandys, Scooter2, scooterho, sfrye5853, Skeet, smcneil, Smithee, Sparky44, sprayking, SpringerPop, sundawg, Taranwanderer, Terier, Triguy, troyt, vasnipe, VinceU, wagon52, Whiteknight, wingriders |
| Most users ever online was 1,025, Today at 01:04 PM. |
