Old 09-10-2015, 12:10 PM   #1
JT Strongarm stabilizers help
I installed these on my 5th wheel. I have read on different forums and seen on you tube about bumping the landing gear to make the setup "rock solid." So my question is do you bump it up or down. Can anyone whom has these on there 5th wheel weigh in on this?
OKI Marine is online now   Reply With Quote
Old 09-10-2015, 12:34 PM   #2
iceblaze580's Avatar
Bump it up you want to take the slack out
iceblaze580 is offline   Reply With Quote
Old 09-10-2015, 12:42 PM   #3
TURBS's Avatar
Either way would do it no?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
Old 09-10-2015, 12:54 PM   #4
I found on mine it will still move if push the jacks down if I push the front end up it is almost solid
Old 09-10-2015, 12:59 PM   #5
Witch Doctor's Avatar
Bump up and retighten.... Try it both ways and see what works for you.
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-10-2015, 01:49 PM   #6
dieselguy's Avatar
You'll never get a rock solid setup on an RV unless you block it up off the suspension. I have JT's and they work well for getting the wobble out, but you still have the bounce. The instructions kinda sorta say
level RV, then drop front back down about 3/4"
drop rear jacks down and tighten JT's
raise front lacks to level again and tighten JT's
bump front jacks up
dieselguy is offline   Reply With Quote
stabilizers
