Old 06-10-2013, 12:10 PM   #1
RPAspey's Avatar
moisture resistant TV..
My kid's swim club needs to replace a LED tv near the pool deck. The last one was a cheap 26" and it lasted 3 years. I'd like to replace it with a better suited TV. At work we have environmental sealed electronics, but I've never heard of a TV like that. Then of course is the $ factor. I don't want to spend a fortune. A sealed box won't work as the moisture will still permeate. Actually I think the bigger cause of failure here is the presence of the pool chemicals reacting to the rubber/plastic components, causing them to fail.
Anyway does anyone have a suggestion for a TV?
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 06-10-2013, 12:47 PM   #2
Camping Buddys's Avatar
Check this one out, will bite deep in your wallet, but it is an outdoor tv.
46" LED "Smart" Outdoor TV - Sky 4630 $2,799.00
I would keep buying regular led/lcd TV's and the extended warranty for it.
just my 2c's.
SkyVue Outdoor TV | 46 inch LED All Weather TV | Skyvue TV |Best Outdoor TV of 2013| LED Weatherproof TV, All Weather TV
John, Lilly & the kids.
2013 Surveyor Select SV 305
2011 Toyota Tundra crew max 5.7
http://campingbuddys.shutterfly.com/
Camping Buddys is offline   Reply With Quote
Old 06-10-2013, 05:08 PM   #3
RPAspey's Avatar
those TV's use a cooling fan that draws air in. Besides price they won't work.
I like the idea of an extended warranty but, I wonder if that may cost as much as the TV.
Old 06-10-2013, 05:24 PM   #4
The tv in our pool deck did last a long time, well, it still works after 7 years! And we have conservation area behind our house. It is under the porch, rain, dust, winds, bugs, and still working!
The ext. warranty usually cost like $49.00 to $69.00 depend of the size of the tv and no questions ask in walmart/best buy if you need to fix it. (Replace)
Old 06-10-2013, 05:49 PM   #5
This enclosure
The TV Shield - Outdoor TV Enclosure Cabinet Cover for LCD LED Plasma
Also silica gel packs in the cabinet will absorb moisture well, they can be recharged periodically by drying them in a low temp oven.
2011 A-122
rawlus is offline   Reply With Quote
