Old 05-06-2014, 07:26 AM   #1
TURBS's Avatar
(Moved) Off topic posts about propane hoses
The hoses themselves are designed to leak.
TURBS
Sabre owners united!
Old 05-06-2014, 07:33 AM   #2
Originally Posted by f1100turbo View Post
The hoses themselves are designed to leak.TURBS
And where did you find this? Are they designed to leak the entire length or just at the fittings?
Old 05-06-2014, 08:15 AM   #3
Herk7769's Avatar
TURBS
Really? Wow. I never knew that.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 05-06-2014, 08:21 AM   #4
Sure, it keeps customers coming back and increases their profits in the lp gas companies.
Old 05-06-2014, 09:01 AM   #5
TURBS's Avatar
Sorry I miss spoke I confused propane hose with a/c hose which has tiny tiny pin holes to allow it to leach.
Look closely to a a/c hose and you'll see the pin holes in a row.
Anyway I was wrong in what I was talking about per application.
TURBS
Old 05-06-2014, 09:07 AM   #6
Sorry I miss spoke I confused propane hose with a/c hose which has tiny tiny pin holes to allow it to leach. Look closely to a a/c hose and you'll see the pin holes in a row. Anyway I was wrong in what I was talking about per application. TURBS
If that's the case, it would require re-charging the ac periodically. The holes must be plugged on TOWTA's old 96 junker and my 05 Silverado as neither have been re-charged.
Old 05-06-2014, 09:43 AM   #7
TURBS's Avatar
I think the "leaking" is negligible.
Go look at your hoses
TURBS
Old 05-06-2014, 09:57 AM   #8
TURBS's Avatar
Ppm im guessing.
TURBS
Old 05-06-2014, 10:02 AM   #9
Go look at your hoses. TURBS
I would think after 18 & 9 yrs respectfully they would at least need a touch up.
Old 05-06-2014, 10:23 AM   #10
TURBS's Avatar
Maybe it does?
TURBS
Old 05-06-2014, 10:27 AM   #11
Maybe it does? TURBS
Could be, but they will both freeze you out within minutes.
Old 05-06-2014, 11:01 AM   #12
TURBS's Avatar
Common symptom of being low -ish on freon.
TURBS
Old 05-06-2014, 11:08 AM   #13
Common symptom of being low -ish on freon. TURBS
Because they work? They don't freeze up inside or outside, they will just cool as good as they always did at least on my truck, don't know about TOWTA's, but it will run you out pretty quickly and have your raising the temp.
Old 05-06-2014, 04:37 PM   #14
f5moab's Avatar
Freon is a gas that is supposed to be recaptured when possible. It should not be leaking into the atmosphere by design. It does when hoses break.
f5moab is offline   Reply With Quote
Old 05-06-2014, 04:42 PM   #15
They are talking about the gas leeching thru the lines like air leeching thru a tire. The holes they're talking about is to keep the hose cover from bubbling and separate from the hose. Nothing to worry about plus I don't think they use R12 or R22 Freon anymore.
Old 05-06-2014, 06:20 PM   #16
f5moab's Avatar
Ok. But even the newer R134a used in auto applications is recovered.
Old 05-06-2014, 06:30 PM   #17
All Freon is suppose to be recovered, but sometimes it just is not feasible or rather possible such as a blown hose, condenser or compressor.
