Old 04-25-2012, 07:41 AM   #1
Name This Tool
What is a Ford wrench? never heard of this kind of wrench in my life!
capucine is offline   Reply With Quote
Old 04-25-2012, 07:44 AM   #2
Herk7769's Avatar
Ford Wrench:
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 04-25-2012, 08:01 AM   #3
Herk7769's Avatar
While I don't carry it in my camper, I have an old one that most likely dates back to the Model A Ford tool kit it came from. It sits in my garage tool chest and I use it quite often.
Old 04-25-2012, 08:06 AM   #4
It looks like a tool that was invented before my time. A piece of collection.
Old 04-25-2012, 08:08 AM   #5
They were also called a "monkey wrench". I have an old tire inflating tool my grandfather used on the farm that they had to remove a sparkplug from their car/tractor/truck and insert an adaptor into the sparkplug hole and let the engine pump up the tire.
Old 04-25-2012, 08:15 AM   #6
Herk7769's Avatar
I thought a "Monkey Wrench" was a "pipe wrench" (does not have flat surfaces but aggressive teeth). Need to look this up to be sure.
HAH! We are both right!
http://en.wikipedia.org/wiki/Monkey_wrench
It refers to any adjustable jaw wrench apparently.
Oops I read that wrong. ONLY a flat jaw one is a monkey wrench.
A pipe wrench is still just a pipe wrench.
Old 04-25-2012, 08:16 AM   #7
Interesting...I've learned my new piece of info for the day...and it's only 8:15 in the morning!
So it looks similar to a pipe wrench, but with smooth jaws.
2012 Flagstaff 8528 BHSS
2008 Ford F250 Crew Cab 4x4 6.4L Power Stroke
fordmantpw is offline   Reply With Quote
Old 04-25-2012, 08:29 AM   #8
TURBS's Avatar
That's interesting!
In todays world you'd be hard pressed to find the spark plugs let alone if it even had one!
My dw has a hard enough time just PUTTING air in a tire much less overhaulin the engine to do it!
Example) the other day she says her tire light was on so she pulled up to the air hose in the shop and looks at all four tires and makes an educated decision on which one was infact LOW.
she then procedes to fill the one up that to the best of her knowledge looked low.
Hmmmm ............ she texts me later and writs I quote. "Tire light came on so I filled up the low tire but the lights still on please check it tonight"
So I get her tire gauge out of the ds door pocket and start from ds front 38
Ds rear 36 Ps rear 25 and finally Ps front 68
you get the point
Old 04-25-2012, 08:36 AM   #9
Herk7769's Avatar
The monkey wrench is an adjustable wrench, a later American development of eighteenth century English coach wrenches. It was popular in the nineteenth and early twentieth centuries but is now used only for heavier tasks, having been mostly replaced by the lighter and sleeker shifting adjustable. The term monkey wrench is also used colloquially (and mistakenly) to refer to the pipe wrench, owing to their broadly similar shapes.
Ratchets, Sockets & Wrenches | Wrenches-Adjustable | Adjustable Monkey Wrenches, FACOM FA-105.280 | B334633 - GlobalIndustrial.com
Yea, I got that and posted in my edit.
Old 04-25-2012, 08:43 AM   #10
Rugged Brown's Avatar
We used Monkey wrench and Stillson synonymously in our neck of the woods. Never heard it referred to as a Ford wrench before.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 04-25-2012, 09:03 AM   #11
Try these on for size. Can anyone identify them?
ID:	12768   Click image for larger version
ID:	12769   Click image for larger version
Old 04-25-2012, 09:07 AM   #12
Herk7769's Avatar
The top one is a saw tooth setter.
Drawing a blank on the other two.
Old 04-25-2012, 09:08 AM   #13
Herk7769's Avatar
The second one looks like a plumbers faucet stem wrench.
Old 04-25-2012, 09:24 AM   #14
Herk, you are the first person I have shown that to that knew it was a handsaw tooth setter, amazing. I will wait a little while and let others guess the other two.
Old 04-25-2012, 09:44 AM   #15
Wow, can't believe we went from installing an anode rod to setting saw teeth, and all the same thread. Maybe somebody needs to start a thread with old tools, and what they are
Could title it: Name this tool. First prize could be a free year on Forrest River Forums.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-25-2012, 01:43 PM   #16
Herk7769's Avatar
I agree. Now it has its own home.
Old 04-25-2012, 01:55 PM   #17
OK, way to go Herk, here is a good one, name them all. They were some of my grandfather's tools I have had since his death in 1978.
Name:	Grandpa's Tools.jpg
Old 04-26-2012, 12:54 PM   #18
This wrench came in the tool box with this car which we think is a 1909 Ford model R (note the RH steering) in which my grandfather and grandmother are sitting. The wrench must be one of the original "fit all" wrenches made. It has similar sizes on the reverse side to fit numerous other things.
Name:	Grandpa & Grandma Dunn 1909 Ford Model R.jpg
ID:	12825   Click image for larger version
Old 04-26-2012, 01:08 PM   #19
This tool was used on old wood cook stoves. The pointed end end was used to lift the 4 round plates that covered the cooking surface and allowed the cook to put additional wood in the fire. The end with the rectangular slot is the end they used to insert over the shaker grate lever that stuck out on the bottom of the stove just above the ash cleanout door. It was then moved from side to side to shake the ashes down into a sheet metal pan which was then removed and the ashes were either thrown out or saved to make soap. The tool was usually stored in one of the back plates on the stove top. There was also a door under the cooking surface and above the cleanout door to allow for the initial loading of firewood, paper, kindling and starting the fire. I ate many meals cooked by my grandfather on this kind of stove.
Old 04-26-2012, 01:11 PM   #20
TURBS's Avatar
Nice history lesson!
