Closed Thread
Old 07-01-2013, 07:45 PM   #10061
SYE
SYE's Avatar
Originally Posted by OldCoot View Post
Took a pc of 2-1/2" x 1/8" sq tubing 26" long and split it length wise and made (2) 2-1/2 x 1-1/4 C channels, measured back 5" on both ends, notched and bent it down 8į, welded the notch and cut it straight and skip welded it to the outside of each leg and across the ends. If you look at Glenn's you will see that the legs are thicker with tapered ends. The added pcs are just below the strut bolts.
Looks Nice, I do not know who Glen is but he is lucky to know you, let me guess, he nwears bibs as well
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline
Old 07-01-2013, 07:47 PM   #10062
TURBS's Avatar
Iph he doesn't he will by time he leaves oc's
TURBS is offline
Old 07-01-2013, 07:48 PM   #10063
SYE
SYE's Avatar
Scott & Vicki
SYE is offline
Old 07-01-2013, 07:49 PM   #10064
AquaMan's Avatar
That definitely gives it a stronger leg, but is that the weakest link in the setup? Is there a noticable difference in stability with a stronger leg? I was thinking of doing some sort of "criss/cross" arms, or arms going forward. I think the weakest link in these stabilizers lie in the angle braces, but I haven't studied them enough, nor have I done any testing. I can see some benefit from your mod though.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
AquaMan is offline
Old 07-01-2013, 08:31 PM   #10065
IMO, the legs are the weak link, the strap arms are also a weak point, I took mine off and made new ones out of 3/4 black seamless pipe and heated and smashed the ends flat and bent them on the same angle as the straps. I also reinforced the main channel the whole stab jack assy slides in by adding 2 pcs of 2 x 2 x 1/8" angle 63" long on each side of the channel up 3/4" and skip welded the angles to the sides of the channel and skip welded the angles together on top. I can now lift the rear of the trailer and nothing flexes. The motor will bog down but nothing flexes. I think the legs do a much better job of stabilizing the closer to vertical. I also have homemade front to back stabilizers similar to the JT Strongarms.
The only thing we reinforced on Glenn's was the legs themselves.
OldCoot is offline
Old 07-01-2013, 08:38 PM   #10066
SYE
SYE's Avatar
OK Who is Glen?????
Scott & Vicki
SYE is offline
Old 07-01-2013, 08:51 PM   #10067
OK Who is Glen?????
Glenn Jurczyk from Clarksville, VA
OldCoot is offline
Old 07-01-2013, 08:55 PM   #10068
LKicklight's Avatar
Count me in!!
Did we win!
watching "naked and afraid". Strange show.
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline
Old 07-02-2013, 08:20 AM   #10069
Morning Phond Dwellers... Scary quite on the Phond this morning???
Gonna finish mowing and replace the pump on my pressure sprayer. Clean MAX ( my 2500HD D/A).
grayfox is online now
Old 07-02-2013, 08:21 AM   #10070
Finished Glenn Jurczyk's mods, put the 2 awning locks on and the step support so he is now ready to hit the road back to Clarksville, VA. 30Jul we will meet @ junction of I81 & I77 for the trip to Goshen.
Name:	Glenn's Awning Lock 1.jpg
ID:	34419   Click image for larger version
Name:	Glenn's Awning Lock 2.jpg
ID:	34420   Click image for larger version
Name:	Glenn's Awning Lock 3.jpg
ID:	34421   Click image for larger version
Name:	Glenn's Awning Lock 4.jpg
ID:	34422   Click image for larger version
Name:	Glenn's Step Support.jpg
OldCoot is offline
Closed Thread
