Closed Thread
Old 07-24-2013, 04:37 PM   #11371
Rolling buckeye's Avatar
Originally Posted by OldCoot View Post
Strongly suggest you get a wet bolt kit for the suspension.
Looking it up next! Ya I didn't like all the rust,thought humm,need to do something about that ! This I did not think oph ! Thanks OC !
Rolling buckeye is offline
Old 07-24-2013, 04:42 PM   #11372
Learned that the hard way! Make my own now, just grind a small flat on the bolt shank, cross drill a small hole in the center and drill a hole in the head of the bolt to the center cross drilled hole and thread it for a fitting.
OldCoot is online now
Old 07-24-2013, 04:57 PM   #11373
Ok OC This will be at the top o my list. But not something I can do right away. So for now, scuff with sand paper,spray off with break clean,lithium grease at bolt, Then maybe a shot of blk paint,at old bolt holes ?
Old 07-24-2013, 05:06 PM   #11374
TURBS's Avatar
One my flagstaff
I'm a cheap a#@ I just took my bolts out and drilled them and added grease zerks.
Total cost $5.00
TURBS is offline
Old 07-24-2013, 05:18 PM   #11375
Iph I get new bolts, to practice or may be drill n install zerks,then install. Would t get g 8 in matching size or more ? Hole before tapping to zerk thread, bout 1/16 "? Only in end ways, 1/2" - 3/4", then connect hole from side 1/16 also ?
Old 07-24-2013, 05:22 PM   #11376
TURBS's Avatar
I used tap in grease zerks so I didn't have to tap holes.
Whatever size drill that was required for tap in zerks I used to cross drill bolts.
I connected cross drill and side drill but not all the way through.
Maybe 8 minutes per bolt till I got it down pat then a couple minutes to drill and hammer in zerk.
TURBS is offline
Old 07-24-2013, 05:47 PM   #11377
Ok cool, but what grade bolts are they. ? N this is a dumb question but,which end ? Head right ?
Old 07-24-2013, 06:20 PM   #11378
TURBS's Avatar
Mine were grade 5.
Correct I Drilled from bolt head end.
By the way I used the original bolts as there was nothing wrong with them.
TURBS is offline
Old 07-24-2013, 06:24 PM   #11379
Excellent ! Thanks !
Old 07-24-2013, 06:36 PM   #11380
Phat Phrog
RVChick's Avatar
Ok girl talk time.....I'm just sayin.....
So Turbs.....I am going to fix your onion bombs this Friday night at our family float! There are several in the Phamily that love to cook....so I am gonna impress em with a phellow Phrog treat!
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline
Closed Thread
