Closed Thread
Old 10-11-2013, 12:02 PM   #14231
TURBS's Avatar
My fishing guide.
Yep she was on um!
TURBS is offline
Old 10-11-2013, 12:13 PM   #14232
TOWTA now has a new windshield and can drive the car if she wants. It has a 1:10 "drive away time". The man was fast, efficient and very professional. Safelite AutoGlass.
OldCoot is offline
Old 10-11-2013, 12:21 PM   #14233
B47
They advertise quite a bit on our TV channels - so your damage exceeded the limits for a repair?
B47 is offline
Old 10-11-2013, 12:35 PM   #14234
Yes, couldn't be covered with a $1 bill.
OldCoot is offline
Old 10-11-2013, 12:40 PM   #14235
B47
So that's the damage limit criteria they use
Did they use what I'm calling a "Fixture" to help line up the new windshield into the frame?
They show it briefly on their commercial.
B47 is offline
Old 10-11-2013, 12:49 PM   #14236
He sure did, stuck a dual suction cup device on the drivers door and 5 on the windshield, one had a telescoping articulated rod on it which he placed in a saddle that was on the drivers door glass and just pivoted the windshield around and set it in place on the passenger side, went to the drivers side, removed the rod and set the windshield in place. Pressed it down all around, taped it up to the roof to hold it in place and started putting things back together. They sure have a neat way of cutting the glue that holds it in. Stick a square sided wire down thru a slit they make at the bottom of the windshield, pull it out and go completely around the edge, put one end on a spool with a ratchet on the inside and just start ratcheting the wire in. Took about 2 minutes.
OldCoot is offline
Old 10-11-2013, 12:56 PM   #14237
B47
I figured they had to attach the device to the vehicle somehow. I worked in a collusion shop many years ago while in High School and back then a lot of windshields had those ugly black rubber gaskets holding them in and you installed a cord in the channel to pull the gasket up onto the windshield.
Things sure have changed.
B47 is offline
Old 10-11-2013, 01:00 PM   #14238
TURBS's Avatar
Very good spirits here!
TURBS is offline
Old 10-11-2013, 01:01 PM   #14239
He put a new rubber type gasket on the top of the windshield in addition to running a 1-1/2" tall, triangular ribbed bead of glue completely around the mounting surface. Neat head on the battery powered caulking gun.
OldCoot is offline
Old 10-11-2013, 01:02 PM   #14240
TURBS's Avatar
Same thing next door...
TURBS is offline
Closed Thread
