Closed Thread
Old 10-25-2013, 07:58 AM   #14531
Phat Phrog Phlunky
essness's Avatar
Originally Posted by Lynkage View Post
I have 4 traps and use about a 1/2-2/3 a gallon for them. I keep my system dry for the winter because the DW does not want that stuff in her water lines.
I do put about a 1/2 a cup on top of the rubber seals in the thrones.
Thanks Lynk, I leave mine dry as well. It's just easier than have her always question if I rinsed it enough when we return to service
Scot, I am "that guy"
2014 Raptor 27FS
2014 Ram 1500 Laramie
Days camped in 2013 = 30 final.
Days camped in 2014 = 27 final.
igkra.com
essness is offline
Old 10-25-2013, 08:00 AM   #14532
Lynkage's Avatar
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline
Old 10-25-2013, 09:51 AM   #14533
PPST OGCDG
Frank-VA's Avatar
Originally Posted by f1100turbo View Post
I run mine thru the whole system....
Its what I do.
I now Blowout the water lines and leave them dry. I only use the pink stuff in the traps
Turbo you to invest in this: Quick Turn By-Pass Kit - Camco 35983 - Winterizing - Camping World
I installed mine after W-L-A-T Brand Antifreeze messed up the Water
filter housing.
The new one is on the left
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline
Old 10-25-2013, 01:11 PM   #14534
The water bypass kit is (VERY) restrictive! Your F/W suction side of the pump travels thru this,also. The Pics show Dia.of hose from tank and the hole Dia.thru the Valve,noted by drill bit reference! Now you also must realize that the On/Off internal bore is (ONLY 1/2) of the in and out Bore. If you are happy with LOW volume supply in your R/V put one of these in your Suction supply Hose! Youroo!!
ID:	41745   Click image for larger version
ID:	41746   Click image for larger version
youroo is offline
Old 10-25-2013, 06:02 PM   #14535
filter housing.
Frank-VA is the one on the right for (White Lightning)? Youroo!!
youroo is offline
Old 10-25-2013, 07:02 PM   #14536
PPST OGCDG
Frank-VA's Avatar
Now That I do not put Antifreeze through the fresh water lines,I will probably remove the By-Pass.
I wonder if the valves could be drilled out with out messing up the valves?
By putting White Lightning in the fresh water lines I will not need to disinfect the lines in the spring with Clorox
Frank- VA {:-{)
Frank-VA is offline
Old 10-25-2013, 08:50 PM   #14537
ses
ses's Avatar
Disinfect?, you'd be lucky to have fresh water lines period! seriously though, you'd have people lined up ,in the spring, when you open the camper up wanting to "help"
ses is offline
Old 10-25-2013, 09:22 PM   #14538
Phat Phrog
RVChick's Avatar
So here is how we looked yesterday
Here is today!
This is my favorite! This is looking from the east to the west, and the shape of the ceiling trusses! Should make the room look very spacious!
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is online now
Old 10-25-2013, 09:22 PM   #14539
Phat Phrog
RVChick's Avatar
Well that showed up backwards....Ha!
Kenny n Karen
Old 10-25-2013, 09:28 PM   #14540
Looking good, should be under sheathing tomorrow!
OldCoot is online now
Closed Thread
