Closed Thread
Old 10-25-2013, 09:38 PM   #14541
Phat Phrog
RVChick's Avatar
Thanks OC! They don't work on weekends....and I can't blame them.....they get here at 7 and stay until 5. It is just amazing how three or four guys can do so much in a day!
Framing for the porch came this evening. My head is spinning!
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline
Old 10-25-2013, 10:07 PM   #14542
PPST OGCDG
Frank-VA's Avatar
RVC & Kenny thanks for the pictures
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline
Old 10-26-2013, 05:56 AM   #14543
Originally Posted by youroo View Post
The water bypass kit is (VERY) restrictive! Your F/W suction side of the pump travels thru this,also. The Pics show Dia.of hose from tank and the hole Dia.thru the Valve,noted by drill bit reference! Now you also must realize that the On/Off internal bore is (ONLY 1/2) of the in and out Bore. If you are happy with LOW volume supply in your R/V put one of these in your Suction supply Hose! Youroo!!
Frank-VA,There would be (Nothing) left of the (Plastic Ball Valve) if drilled out to incoming hose size. Youroo!!
youroo is offline
Old 10-26-2013, 07:16 AM   #14544
Looks like it could be drilled out to 7/16" or 1/2" to match the bore.
OldCoot is online now
Old 10-26-2013, 07:27 AM   #14545
OC,send me (Your Valve) and I will Bore it out,and send you what is left! Youroo!!
youroo is offline
Old 10-26-2013, 07:31 AM   #14546
I could bore it out, but I don't even use it. Never winterize. Just take the valve out and put in a couplers, remove the vertical pipe and save all that weight.
Old 10-26-2013, 07:37 AM   #14547
Frost all over the yard here this morning, 27°. Time to speed up packing for FL.
Old 10-26-2013, 07:41 AM   #14548
A Tee would defeat the (Convenance) that people want to just (Turn a handle) to go from F/W too A/F bottle,without removing or adding anything! Youroo!!
youroo is offline
Old 10-26-2013, 07:49 AM   #14549
Understand youroo, just messin' with you. As I said, I don't winterize and therefore don't use it. In my case, I could take the whole mess out, but I'll leave it as it is in the back under the cabinets and extremely difficult to get to and someone else might use it.
Old 10-26-2013, 07:58 AM   #14550
I know what you mean OC. F/R can sure (Hide) the Water filter Assy.I tried to locate the (Double jointed-5 foot armed-Amish Filter Installer at the F/R Factory) never could locate him/her? Youroo!!
youroo is offline
Closed Thread
