Closed Thread
Old 10-26-2013, 08:03 AM   #14551
Originally Posted by youroo View Post
I know what you mean OC. F/R can sure (Hide) the Water filter Assy.I tried to locate the (Double jointed-5 foot armed-Amish Filter Installer at the F/R Factory) never could locate him/her? Youroo!!
My water filter is relatively easy to get to, just remove a small panel in the basement and it's right there. Use to have to remove 4 screws, I took them out and installed (2) 1/4" spring loaded pins compliments of the USAF.
OldCoot is online now
Old 10-26-2013, 08:20 AM   #14552
Originally Posted by OldCoot View Post
My water filter is relatively easy to get to, just remove a small panel in the basement and it's right there. Use to have to remove 4 screws, I took them out and installed a 1/4" spring loaded pins compliments of the USAF.
I was referencing the (100s) of members who ask where their W/Filter is. Bet those (Pins) cost 500.00$ each! Youroo!!
youroo is offline
Old 10-26-2013, 09:06 AM   #14553
...Bet those (Pins) cost 500.00$ each! Youroo!!
At least.
Old 10-26-2013, 09:24 AM   #14554
TURBS's Avatar
Playin farmer today.....
TURBS is offline
Old 10-26-2013, 09:53 AM   #14555
Notice they both have sleepers. Ms. Amy will do the work as usual while FT Turbs is either asleep or passed out in a sleeper. Don't see any combines.
Old 10-26-2013, 10:05 AM   #14556
TURBS's Avatar
He's in the back 40 ain't seen him all morning.
Just the auger cart n tractor.
TURBS is offline
Old 10-26-2013, 10:06 AM   #14557
TURBS's Avatar
TURBS is offline
Old 10-26-2013, 10:11 AM   #14558
Must have a JD and he's working on it. When we were in 150bu/acre corn, we filled a 200 bu grain hopper every 7 minutes if we stopped to unload and every 9 minutes if we unloaded on the go. Grain carts/trucks just followed alongside the combines.
Old 10-26-2013, 10:27 AM   #14559
PPST OGCDG
Frank-VA's Avatar
On our Wildcat the filter and the pump is located on the left side basement just to the left. Perfect location.
29 degs here this morning and the yard was all white.
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline
Old 10-26-2013, 10:31 AM   #14560
Same here Frank only the temp was 27. TOO @#$% COLD! Going to have to sweet talk TOWTA into moving the exit date to FL up from Fri after Thanksgiving to tomorrow. I'll brave the cold today and hook up.
Closed Thread
