05-03-2013, 05:25 PM
#5401
old number 7 is a mule otherwise known a jack a#$
I dont think A picture is needed in this case ..............
05-03-2013, 05:29 PM
#5402
I thought I had it right. Heeee HAaaawwww!
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
05-03-2013, 05:30 PM
#5403
If you want to call me a jack a#$ or a mule then just do it. As I said before, I heard of the show but never watched it.
05-03-2013, 05:31 PM
#5404
B you make some days BRIGHTER for me !
05-03-2013, 05:49 PM
#5405
OK headed to the shop as my awning poles are waiting to be drilled and painted.
05-03-2013, 07:46 PM
#5406
Lowers drilled and painted drying.
Upper mount drilled/ over sized the upper tube then installed an aluminum bushing with 1/4" id bushing.
Deployed position.
Stowed postion.
05-03-2013, 07:49 PM
#5407
Self locking nut - that's good. need at least two threads showing after proper torquing
05-03-2013, 08:03 PM
#5408
An FAA requirement?
Thanks B eeer aaa 7
05-03-2013, 08:07 PM
#5409
An FAA requirement?
Thanks B eeer aaa 7
Let's just say it is a good aeronautical practice. It is in some FAA Advisory Circulars.
Think about it - what good does a self locking nut do if not all its threads are engaged?
05-03-2013, 08:08 PM
#5410
The locking nut in this application is not torqued but just screwed on enough to bottom the bolt and washer against the bracket sides. It is just a pivot for the pole.
05-03-2013, 08:09 PM
#5411
In this application, just to keep it from falling off.
05-03-2013, 08:10 PM
#5412
Pole pivots on bushing so infact the nut does get locked tight and torqued.
05-03-2013, 08:12 PM
#5413
In your two bottom photos it looks like the nut is simply hand tightened and it doesn't look like the bolt and washer are bottomed out. I thought at first look that you had just "dry fitted" it together.
05-03-2013, 08:13 PM
#5414
So if the pole does not pivot on the bushing, the bushing will turn in the bracket?
05-03-2013, 08:15 PM
#5415
Come on - show me at least two threads showing on the bolt.
05-03-2013, 08:18 PM
#5416
It is just mocked up to test fit.
Paint is next.
05-03-2013, 08:20 PM
#5417
Bushing goes all the way through pole not just on outsides.
Make sense?
I can take it apart and show you if your not clear.
05-03-2013, 08:24 PM
#5418
Exactly - so torque the nut enought so all of its threads are engaged and it won't fall off.
05-03-2013, 08:28 PM
#5419
Make sense?
So does the bushing bottom on the insides of the bracket or go thru the bracket legs also?
05-03-2013, 08:40 PM
#5420
Bottom on bracket sides.
